If you do run synchromesh just make sure you change it pretty often. A lot of people like to put transmission fluid in and just forget it.
1995 Dodge Stealth R/T Turbo
The ford stuff was a god send to my speed 3 transmission.
Finally did something to the R/T. Was running an open downpipe to move it around, which was quite obnoxious. Pieced together an exhaust for it from an old cat, catback, and pipe I had laying around. Now it's only slightly obnoxious since the flex is broken. My GOD that car SMOKES. Looked like my garage was on fire. Once the body work is done, I'm gonna need to rebuild the motor!
Also prepped the VR4 to be torn half apart to fix a $5 gasket (front turbo return). Was planning to hit the track Friday, probably not an option now.![]()
Finished manual aa wing with stock switch mod.
Installed h4 "projector" lenses and HIDs.
Supplied 4 blood sacrifices to my VR4.
WTF! Must be from Cali...
Start up on Buhrman's Evo soon!
Sent from the Man Cave!
3 hose clamps, and 2 foot of vac line short of lift off.
Prime n start time. Had a few leaks to chase.
