Moved it for the 1st time in a month. Don't want to go far with no exhaust, lol.
Just needed it out of driveway so I could cleanup my mess.
New clutch feels nice. No more chatter.
I also apparently did a much better job at bleeding the clutch this time. Nice and tight![]()
Finally got around to replacing my clutch line with a replacement from Ninja Performance. Glad to be back in my VR4 instead of my 87 F250 (60 mph top speed) I've been driving the last two weeks.
Found the RWD Switch....
No really...BAD VCU I guess
VCU transfers both ways, at least I think... but usually the fronts spin first because you load more weight transfer on the back when launching.
1995 Dodge Stealth R/T Turbo
Finally got around to fix the venting for my battery box located just behind the rear seats.
^ Nice work!
Sprouted an oil leak. Front turbo feed at the banjo bolt. Hopefully just needs new crush washers.
changed my transmission oil , switched to redline 75w-85 from synchromesh
Just curious. did you dislike the synchromesh? Any problems with it or did it work well for you? I heard some people love it, others hate it. And it is the cheapest i've seen pricewise.
This time around I went with some mobile1 synthetic, but was tempted to try the lucas.
