Page 505 of 892 FirstFirst ... 5405455495503504505506507515555605 ... LastLast
Results 5,041 to 5,050 of 8916
  1. #5041
    JNS Engineering verified
    San Jose, CA
    Drove it and enjoyed the new power level. It's as though my gears have changed. 3rd gear feels like 2nd used to, and 2nd gear feels like 1st used to. 1st goes by so quick I can't really gauge it. Wonder how much more power I need to make 3rd feel like 1st used to.
    Another success story with Chrome and cool that you self tuned. This is the route I want to take as well.
  2. #5042
    Iceland / Europe
    94 SL | 96 SL | 91 R/T | 93 SL | 94 ES | 95 SL | 92 VR-4 | 91 SL | 93 ES < gone | curent > 95 VR-4
    ............................ AUGUST 2010 RIDE OF THE MONTH !!
    ................................... 2010 RIDE OF THE YEAR !!
  3. #5043
    Dropped off the re-re-built calipers and the powdered rear rotors to Sublime_whatigot (Matt) tonight I get the following picture and news that they do not leak.
  4. #5044
    Sure can't complain about the looks of that.
    Steve, you'll be wanting to pull a tire after running the NG AutoX to shine a light down through the rotor to see how the coating inside is faring.
    If it holds up and you aren't running high-temps, double-win.
  5. #5045
    I don't bite
    Southern IN
    Broke out the flux core, cut and re-welded my 3sx td05 downpipe to fit the 3.0. Fits better than it ever did! Car is quiet again.
    Unfortunately the front header flange to head is leaking. I had asked 3sx if they could still get the composite gaskets that came with the kit but they couldn't. Used a mls, but no bueno. Guess it's time to pull it and get it flattened...again.
    Idling good. Dialing in the vac fueling. No boost runs yet. Weird bucking with light throttle and light load and AEM log shows erratic vehicle speed. Adding more fuel there, but Maybe speed sensor going out??
  6. #5046
    Sounds very familiar. My built 4g63 ate a valve, so I have a stock shortblock in my Dsm for a while. I put it together and drove it, I couldn't figure out what happened to my tune. Idle was fine , but I couldn't rev past 6000, the car was rich while driving, and no power at all, even at 30psi. Well, my vss was not plugged in. I was driving around on my antilag settings. Under 5 mph I run -10* at greater than 35% tps, and 15% fuel enrichment.
  7. #5047
    Apr 2011
    Mid-April 2011.
    Monroe WI
    *******Warning, Explicit language used!!***** (mostly the F Bomb)
    My latest adventure.... Everything that could go wrong...did go wrong...
    FML (sorta my fault, it wasn't going to come out anytime soon I promise)
    FUCK THIS THING!!
    REALLY?!
    All I did was unbolt it from the manifold and pry it away GENTLY with a VERY SMALL screwdriver....
    WHAT The hell...
    Replaced front turbo, installed replacement rear turbo...learned there are different sets of 9B's as seen here. Would not fit into my Turbine housing...so as oppose to pulling the rear manifold and pre cat and turbine housing and all that shit and adding like 4 days worth of work...
    I just rebuilt my old one. (with GENUINE Mitsubishi parts from that "shitty" ebay company called Kinugawa, AN Oil lines on the way from them too!)
    differences seen here:
    (AWWW COME ONE REALLY?!?!)
    ... FML
    Other things that went wrong...
    *ebay downpipe that previously lined up perfectly, decided not to line up AT ALL. dropped it, reinstalled it, had manhandle the rear turbo flange with a big ass pry bar and scissor jack from under the car....
    *Everytime I blinked or thought about moving something fell....
    *Front Turbo I received had a bolt broke off in the Turbine housing, that was half the fucking reason I said fuck it and bought different snails in the first place!! Thanks Will!
    *Broke a total of 5 bolts off in the original turbo's turbine housing when I was removing it...
    Coming Together...
    Installed....
    Yes I know the heat shield is bent.. I did that on purpose.
    I HATE YOU I HATE YOU I HATE YOU I HATE YOU I HATE YOU I HATE YOU FUCK YOU FUCK YOU PLZ DIE PLZ DIE PLZ DIE!!!
    12AM on the dot, she is finished...FINALLY!!
    Except for Alternator, A/C compressor, Belt, and Oil Feed lines...
    Oil feed lines should be here later in the week...
  8. #5048
    I don't bite
    Southern IN
    I pulled too much fuel vs the 3.5 tune so I'm adding some back in and curve is a lot different with the cams. It was sometimes a little lean when it bucked around but not always. Only thing funky on the logs was vehicle speed would shoot up and down during the bucking. Will try it out again today with more fuel but may just need a new sensor, since mine is plugged in
  9. #5049
    I am sanding a headlight lens, I think I am finally happy with the amount of pitting I was able to sand away.
  10. #5050
    Why? Because Race Car. verified
    Wichita, KS
    You mean how much torque you need to make 3rd feel like 1st used to. It's actually a pretty simple calculation.
    91 R/T TT
