Page 497 of 892 FirstFirst ... 397447487495496497498499507547597 ... LastLast
Results 4,961 to 4,970 of 8916
  1. #4961
    Why? Because Race Car. verified
    Wichita, KS
    Been busy over the last couple days. Rebuild has 1000 miles on it but I don't feel I got it clean enough from the spun bearing previously. Sooo....pulling it apart to clean and refresh it again. No big deal ha.
    From this:
    To this:
    Looks like some debris made it through. All of the rod journals look similar to this:
    Off to the machine shop to get polished!
    91 R/T TT
  2. #4962
  3. #4963
    Wrench Monkey Not Verified
    Rochester, NY
    Moar boooost.
  4. #4964
    Quote Originally Posted by Street_Chally73 View Post
    I got my order in from Cherry Hill (thanks again, Mike!!) and got a little sidetracked while figuring out what else I could electroplate since I had a couple things ready for it...I decided to do my thermostat housing bolts and while I was at it, I may as well do some more polishing to clean things up a bit.
    Attachment 5352Attachment 5351Attachment 5350Attachment 5349
    Nice work, I would love to see a build thread on your car.
    Learn how to Powder Coat at www.powdercoatguide.com.
  5. #4965
    RTBOOST verified
    Florence, Wisconsin
    Quote Originally Posted by 99ishVR-4 View Post
    Thanks & I'll probably make a thread once I'm finished with all of these repairs...Until then, I really only keep my CarDomain page updated with each small fix or rebuild.
    Sent from the garage
  6. #4966
    Iceland / Europe
    Quote Originally Posted by IcelandGTO View Post
    In the process of replacing the synchros and doing some maintainence on my engine.
    Fun Fun Fun
    94 SL | 96 SL | 91 R/T | 93 SL | 94 ES | 95 SL | 92 VR-4 | 91 SL | 93 ES < gone | curent > 95 VR-4
    ............................ AUGUST 2010 RIDE OF THE MONTH !!
    ................................... 2010 RIDE OF THE YEAR !!
  7. #4967
    SoSoCal verified
    I installed my new DR side a-pillar, changed out greddy control box for oil temp, tightened up the banjo bolt on my BBK
  8. #4968
    I don't bite
    Southern IN
    Torqued heads down with the A1 Studs. Start degreeing several sets of cams tonight after work.
  9. #4969
    Drove it to Sublime_whatigot to have him replace:
    Driver's CV Shaft w/ Seal (maybe never heard the "clicking sound" that made me think it was bad)
    Struts (with "I not have the closest thing to coil overs without losing the ECS option))
    3SX Adjustable Rear Control Arms & Boots
    Saner Front & Rear Anti-Sway Bars
    IPS Baffled Oil Pan
    3rd Gen Lifters
    Powder Coated Valve Covers
    Valve Cover Gaskets
    Krank Vent Kit
    Powder Coated GZP Cam Gears
    MSD Spark Plug Wires
    NGK Spark Plugs
    Powder Coated TT Plenum
    Plenum Spacer
    EGR Block Off Plates
    T/B Spacer
    Powder Coated Plenum Junction Cover
    Greddy Type S Blow Off Valve
    Powder Coated Pre-Turbo Pipes
    OEM Gaskets
    Ceramic Coated Stillen D/P
    Ceramic Voated 3SX Rear Pre-Cat Delete
    3SX Poly Motor Mounts
    JDM Front Brake Ducts
    Change Out the all the Oils in the car.
    FINALLY, after collecting parts for two years, I was beginning to wonder if they would ever get put on the car.
  10. #4970
    Jun 2011
    Sweden, Gothenburg
    IPS Baffled Oil Pan
    3rd Gen Lifters
    Valve Cover Gaskets
    Krank Vent Kit
    NGK Spark Plugs
    Plenum Spacer
    T/B Spacer
    OEM Gaskets
    damn that's alot of work. Understandable that you don't want to do all that yourself
