Happened to me once.
put some of my big tyla ground wires on hoping it would help alleviate my starter issues. maybe its the starter thats the problem...?
1991 Stealth RT/TT forged crank, new pistons/bearings/rings, T16's ceramic coated, precat deletes ceramic coated, full exhaust, FMIC, Dijon intake pips, adjustable cam gears.
do you have a link to that smoking?
i replaced my ignition switch last year because that was "supposed" to fix it, however it didnt change. then i thought it may not be getting a good ground since the PO moved the battery to the back, but still no fix.
i know the wire you speak of, but im not sure how to modify it to make it work mo' betta
No, I haven't done a wire up yet. Mist people add a relay tripoed my the original starter wire using the battery for more amperage. I rewired a relay in the fues box to become my starter relay and fix that issue.
Sent from my SGH-T999 using Tapatalk 2
My positive wire to the starter (big fat one) was corroded really badly. Check that too.
Started assembling my struts, then found out the the rear Tein pillow mounts need modification to the collars, so I took them to the local machine shop to have them bored out to the proper diameter.
like a 1/16 of an inch, being that it is solid metal, I have no concerns. The other thing I just did....
Cut the spring perches off my brand new struts!or
Got my bent PS Tie rod replaced and got an alignment and went to get some E85, damn I was busy today
