Page 485 of 892 FirstFirst ... 385435475483484485486487495535585 ... LastLast
Results 4,841 to 4,850 of 8916
  1. #4841
    Wrench Monkey Not Verified
    Rochester, NY
    Took the VR4 and SL out of hibernation yesterday. Fresh oil, took apart and cleaned/lubed the brake hardware, and raised the VR4 from where it was sitting last year (too low). Raised the front 1", and raised the rear .50" higher than the front. Front dampening set full hard, rear dampening set full soft as per what I remember Austin running them at. Hopefully I'll be able to launch this thing at the track this year. Flash tune ECU sitting next to me as I type, waiting for me to hit up the ChromeECU site to figure out how to put it in. 550's waiting for that as well. Took it to one of those touch-less washes for the first time, actually did a good job, but of course it started raining before I got home.
  2. #4842
    Oct 2010
    Coatesville, PA
    Pushed my 99 VR4 about a 1/8 of a mile home with my dad steering.Found to be a blown fuse for the hot wired fuel pump. I think the relay grounded out on a fuel hat nut because none of the connections had electrical tape or heat shrink on them. I also changed the tranny fluid after I fixed the relay issue..
  3. #4843
    Sep 2012
    Decatur, TN
    That car is soooo sexy.
  4. #4844
    Rochester, NY
    Agreed. Thanks!
  5. #4845
    Member
    Chilliwack BC
    Dummied up some new pipes sporting a fresh color.....now all I have to is stop daydreaming at it & finish up the new brake/clutch hydraulics so it can go back in. Crusin weather is approaching
  6. #4846
    I like how the front turbo is feeding off the throttle body :P
  7. #4847
    Feb 2011
    Scottsbluff, NE
    at first I was like WTF about that too, then I realized it was just an optical illusion.
    1995 Dodge Stealth R/T Turbo
  8. #4848
    Apr 2013
    Today, I put my daughter in the car for the first time. She is 4, and she loved every second of it. Took it home and washed it, cleaned up the wheels as well as the engine bay.
  9. #4849
    Quote Originally Posted by `Spencer View Post
    careful, she will want one. my daughter does.
    Worked on fixing some boost leaks, until I fix the monster throttle body leak its hard to find any other ones. Lets hope a new throttle body gasket fixes it...
    Also discovered the oil pan leaks pretty good, seems to be around the seal, going to have to pull it and reseal it.
