Page 476 of 892 FirstFirst ... 376426466474475476477478486526576 ... LastLast
Results 4,751 to 4,760 of 8916
  1. #4751
    I finished all the rum and finished stripping the old short block.
    Now that that is over I can start the pumps and timing part tomorrow.
  2. #4752
    Jun 2011
    Sweden, Gothenburg
    it's a rarity now. and that's because lighting technology has changed to where aerodynamics did not have to be sacrificed in order to light a vehicle. it first started with these:
    Chaparral Cars - Wikipedia, the free encyclopedia
    and when technology finally progressed from sealed beam to projector beam, that was the tipping point. with LED technology now available, i guarantee you will never again see a production automobile with pop-up lights (unless it's a replicar).
    Alright cool never thought that. Thanks for schooling me lol
  3. #4753
    RTBOOST verified
    Florence, Wisconsin
    I broke it some more...
    A big thanks again to Nate for coming through with these!!!
    My old, worn front engine mount:
  4. #4754
    Did a little tuning:
    93 octane.
    15 PSI or less
    To be honest I am not positive about the boost, except it is 15 PSI or less. I don't really have the time to stare at the boost gauge and I didn't have time to hookup my map sensor logging today. I just wanted to get a decent pump gas tune before changing to e85. There are a few bumps to clear out, but this is just with tuning a bit along the road, really the result of only 2 pulls. It is a little fat up top, but I'd rather have it setup this way than chase 10 more HP by leaning it out. It will be time to get the boost logging and start tuning the e85 next. If I start getting over 500 I will probably chill out until the gathering.
    The weight may seem high to you guys, but the car is FULL weight, had almost a full tank of gas, and a passenger with me. I'm around 220 myself.
  5. #4755
    93 octane.
    15 PSI or less
    that's 750's on pure pump, right?
  6. #4756
    RTBOOST verified
    Florence, Wisconsin
    I ordered a pair of StrongArm rear hatch struts, placed an order for various small items I need to re-install the radiator, & plan on doing some more plating & clean-up my fans later tonight.
    Sent from the garage
  7. #4757
    yes pure pump, stock timing as well. I'm sure I could pull 50+ more out of it with just a little bit more boost. I saw absolutely zero knock as it is.
  8. #4758
    yeah, that's what i was thinking. 400whp is very impressive for such a mild tune.
  9. #4759
    thanks, I didn't really expect a whole lot more than that at this boost. Basically running stock afr,timing,heads,cams, etc. Small maf. 97,000 mile engine. Most of the parts I have on the car aren't worth a ton of power at this level anyway.
  10. #4760
    that makes the case for 750's very compelling indeed. i just wasn't certain that they could dish out 600whp on a 3.5L with pure pump--and i'm fairly certain that 16g's can. but we'll see.
