Yup Delta is the one. It's fully up to you but if you're doing everything else all out like I'm sure you will, you don't want to handicap it with cams that don't flow well enough.
1995 Dodge Stealth R/T Turbo
Started the process of swapping in the clutch vac assist into my N/A yesterday for the AWD swap. Ive got the new holes in the firewall drilled and am almost ready to mount the vac assist pedal. Ill grab some pictures after some snow melts off fom the blizzard.
Worked more on my box project...
Outside
Dont mind the bondo holding the plastic together that my old sub box broke
Putting it together and making the sealing sides...
[3SX Test-Pipe to Flow-master Delta 40 Series Custom Exhaust// 99' Lifters // Cold-Air Intake // MB Wheels 5X]
Are the subs setting low enough to not be smacking into the seats? Looks good.
Changed the oil on my VR4 with some fresh Royal Purple![]()
1991 Monza Red VR4- Weekend ride: Tanabe Super Medallion Hyper exhaust, 0.8 bar WGs, Turbosmart MBC (@1 bar), 3SX turbo pre-pipes, Straight pipe, Greddy Type RS BOV, Godspeed FMIC w/ PPE pipes, Stillin DP, HKS duel filters, RPS stage 2 clutch, 3sx SS clutch line, Custom oil catch can w/ braided lines, Krank vents, Ohhnoo's fuel loop, HW fuel pump, PC'd 2G brake swap w/3sx SS lines, Hawk pads, and Stop Tech rotors; Various deletes, PC'd/polished engine stuff, Koyo rad, Greddy coolant cap, DBest custom oil cap, Pit Road M front strut bar, PRM plug cover, PRM tailights, PRM CF Falcon hood and PRM shift knob, Morgan Motorsports splitter, 19x8.5 +27/19x9.5 +24 Volk GT-Cs wrapped Nitto NT555s, 99' bumper conversion, 99' sail panels, 2G side skirts, Retrofitted 5G Celica mirrors, Retro Spec side splitters, RS rain guards, and RS rear window visor, factory GTO light up visors, Custom fit Top Secret style diffuser for 350z, Robo mod w/halos, 3G rear garnish, Momo steering wheel, Tein Street Flex coilovers, 3SX control arms, Apexi turbo timer, Apexi mechanical boost gauge, Zoom Engineering Penta rear view mirror, Veilside navigators foot rest, Pioneer HU
