Page 455 of 892 FirstFirst ... 355405445453454455456457465505555 ... LastLast
Results 4,541 to 4,550 of 8916
  1. #4541
    JNS Engineering verified
    San Jose, CA
    Dropped my block, crank, and heads at the machine shop. The block is getting tanked and honed, the crank is getting micropolished and the heads are getting a valve job.
  2. #4542
    Having 2nd thoughts on BC anything...
  3. #4543
    There's a reason it's BC and not Crower.
  4. The Following User Says Thank You to anyonebutme For This Useful Post:
  5. #4544
    From what little I can find online about these, I just don't feel comfortable with it... Just shot IPS an email cancelling the order for BC springs & Ti retainers.
  6. #4545
    VR-3747 :D Not Verified
    Dayton Ohio
    made a pressure tester today. when the weather decides to cooperate, i will pressure test and probably find 15 leaks haha
  7. #4546
    if you end up getting stuck with it, just run 'em.
  8. #4547
    Jan 2011
    az
    Adam, I don't think the issue was with the springs but more the cams.
    Ross 9:1 piston, H beam rods with arp bolts, *Forged crank,*Ported head with brian crower 1mm over intake and exhaust valves,*Brian crower valve springs,Oem headgaskets,*Arp headstuds*,T3 hybrid turbos with .63ar,*Tial leaded fuel wastegates with 1bar springs,*Cx racing fmic*,Arc2 in blowthru,*950cc delphis on e85,Jackhammer fuel hanger holding 2 walbros 255 hotwired ,Fuel lab fpr,*Aeromotive fuel filter*Entire fuel system done in ptfe braided black lines,*Beefed up oil cooler,*Gates racing belt*,Ninja performance soild tension setup*,3sx single pass radiator*,Tial q blowoff*,Scanmaster*,Aem twin fire*,3sx fuel rails* battery relocated to trunk, blitz dsbc, aem wideband, autometer oil pressure gauge,And so on....
  9. #4548
    Quote Originally Posted by keo92stealth View Post
    The cams are certainly more problematic, but they require a lot more manufacturing precision than springs and retainers. They probably would've been just fine... I just need to do some more cam/cam gear/spring research to feel comfortable with the decision...
  10. #4549
    Feb 2011
    Scottsbluff, NE
    I'm confused, what's wrong with BC (I assume you mean Brian Crower) stuff? If you are referring to the cam profiles being a bit wonky I'm not sure there is a proven cam manufacturer for our cars... I know Jack's wont install any regrinds for the 6G72. ABM knows more about that than I do. Isn't there a cam manufacturer that you can give them the specs you want and they will make them?
    1995 Dodge Stealth R/T Turbo
  11. #4550
    Quote Originally Posted by DK77 View Post
    Delta cams? But yeah... I'm not hell bent on ditching OEM stuff (other than the cam gears)...
