Page 437 of 892 FirstFirst ... 337387427435436437438439447487537 ... LastLast
Results 4,361 to 4,370 of 8916
  1. #4361
    Hell of a start Nick!
  2. #4362
    I don't bite
    Southern IN
    Backed it off the trailer today after journey to Ray's. Launched it HARD for the first time in a LONG time. Perfect street launch with all 4 just barely breaking traction...still got it...or just need more power to overwhelm tires
  3. #4363
    JNS Engineering verified
    San Jose, CA
    Got to this point today. It appears my crank resistance is a rod bearing issue although none of them spun. Also there are no chunks in the oil and no visible damge to any piston looking from the bottom. So far I just have 1 bad piston and 1 bad valve and rod bearing resistance:
  4. #4364
    Dad verified
    01 Apr 03 - Jokes on me
    NJ
    Careful with that crank bolt. I would put on the pulleys with that bolt.
  5. #4365
    Banned J. Fast's Avatar
    What's the crankwalk endplay spec on it?
  6. #4366
    One fix at a time verified
    Kansas
    Not today but almost a month ago I ended up blowing up my front turbo at 28 psi. I'm not exactly sure what happened but the shaft sheared and at some point whether before or after the compressor nut came off. The chunks got the rear also. No wonder I had a huge loss of power. At least the motor survived. I expected it to blow first. I guess I get that for pushing things hard.
    Last edited by TurboSinceBirth; 03-10-2013 at 03:27 PM. Reason: Updated photo links
  7. #4367
    FYI, I'm using one of these... it's an industrial disconnect for a Mitsubishi Forklift. It's the same thing you've depicted except it cost $15 on E-bay. They come in Red or Grey and are rated for 175 amps and 600V (high voltage). My battery is located in the trunk. I love the snap disconnect. I can go to the trunk and unplug the battery and remove it very quickly. It also has a bridge lock so if your racign you can lock it down and tie it to an inline breaker.
    https://www.google.com/search?q=ande...63%3B300%3B231
    Jeremy.
    would you please go into complete detail about you have breakers and what not to make your remote batteries "race compliant"? I have rear batteries and I would like to make a way that I could have a taillight have a switch, but for regular use, use a regular tail light with a jumper bypassing the switch under the tail light...
    If that makes sense.
    Also I now have everything ordered to flash tune but a WBO2 sensor.
  8. #4368
    swapped my seats out, cleaning up the gray car's interior, looks nice
  9. #4369
    San Jose, CA
    Quote Originally Posted by NickS VR4 View Post
    Can't put the pulley on without the crank sprocket. The bolt just bottoms out in the crank which I don't think is an issue as there is no torque on it.
    Not sure yet where / how to measure this. I still need to pick up a feeler gauge.
  10. #4370
    San Jose, CA
    Got the block empty except for a few plugs and squirters. Can I have it hot tanked in this condition?
