Page 412 of 892 FirstFirst ... 312362402410411412413414422462512 ... LastLast
Results 4,111 to 4,120 of 8916
  1. #4111
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Nice engine bay, and nice Tires!1
  2. #4112
    NWPA
    Where did you purchase the 3rd gen lifters from? I've been wanting to do this for a while now
  3. #4113
  4. #4114
    These were delivered and installed...
    fap fap fap
    St.Louis
    Was finally able to get my AWD sub-frame in last night and ran my new fuel line after spraying a thick layer of under coat on the entire rear end of the under-body. All that is left for me to do to get my car driving again (on FWD) is to hook up the brakes and bleed the system then mount my tires of course. I want to drive it so bad.
  6. #4116
    94 3500gt vr2? verified
    NC
    Finally sound deadened the pass side door. Driver side been done for months, lol.
    Also rubber sprayed all inside the door after this. Need to figure out something reusable to seal the openings. Threw the old plastic away because it was all brittle and torn. Velcro and rubber maybe?
  7. #4117
    NC
    Early bday gift to myself
    Arrived intact. Came with downpipe, testpipe and full catback.
    Decent looking bolts, seem sturdy. Don't think I've ever used this type of lock washers before.
    I should have put the whole thing together before putting it on the car, the middle clamping coupler was a pita doing after the rear part was on the car, lol.
    Done
    Sounds awesome. Mild, deep and smooth, not raspy at all. I don't see how it's possible, but I swear it feels like it added a good 10hp.
    Only thing bugging me is the passenger side doesn't sit back inline with the driver side. A small spacer should be an easy fix for that though.
    I also would like to try slightly bigger silencers.
    Can't use this just yet. But it is the last thing needed for my tt conversion
  8. #4118
    Canaan NH
    Just ordered the M2 exhaust last night!!! Hope you like it man.
  9. #4119
    NC
    Loving it so far
    Let me know how yours lines up.
  10. #4120
    You only needed to apply your sound deadener to 25% of the a surface that you covered, but what is done is done. I would also be willing to bet that with all the curves that metal has from the press stamping done, that it does not resonate much. The outer door skin is what is resonating the most.
    A 6" strip placed in the middle of the door horizontally, would help that tremendously. Also how is the bond between the brace in there? If that has aged, then the outer door skin will rattle against it and that is annoying.
    you can use ABS plastic or plastic cutting boards to cut panels to seal off those holes in the door. You get need to get creative around the wire loom and door linkage.
    You are on the right track about the Velcro and rubber idea. To say me typing I give you this link:
    sounddeadenershowdown
    A boatload of info in there, I have his product but have not done my doors yet, just the hatch area.
    Curious about the rubber spray? you didn't plug your drain holes at the bottom of the door did you?
