Received the clutch/pressure plate from S/B... WOOOT! Now if I can only light a fire under the machine shop, and the Beard.![]()
drove it today after installing the aws delete. feels alot nore connected IMO. doesnt float.
Now, i logged today and my shift drops to around 37-3900 rpms after hard in each gear like at the track. should i put my ign cut for nlts around 3800rpms? that was the average for 1st thru 3rd gear?
I replated my fuel injector clips with some tin-zinc electroplating...now they're rust-free & match the rest of the recent polishing craze that I've been on.
Sent from the garage
Actually, Eastwood Company has an at-home electroplating kit for $60.00. Realistically, all that you'd need to buy are a couple tin zinc anode bars & some type of electrolyte solution as long as you have some fine metal hand polish already on-hand...Their kit includes a tube of Autosol, so that's like $16-18 of the total cost.
The solution is: Water, Stannous Sulfate, & Sulfuric Acid, but I don't know the ratios.
I really wish I could go drive my car today...but the weather is nasty and I just washed it....
nothing to do on the car because I am waiting on parts![]()
Finally switched to 3rd gen lifters, tucked the front injector wires, painted my cam gears, resealed my top end, and installed a new timing belt.
1993 3000GT SL
Mods: 95 front end, Robomodded Glass Headlights, VIS CF hood, Megan Racing Coilovers, relocated battery, short ram intake, VR4 Plenum, OBX LSD, OBX longtube headers, test pipe, 3SX underdrive crank pulley, Fidanza 9lb flywheel, Spec stage 3 clutch, solid lower engine mounts, 80a poly filled upper/trans mount, poly front sway bar bushings, Momo steering wheel, 3rd gen lifters, Konig 18" wheels, 4300k HIDs, gutted trunk, AC delete, PS delete, Cruise Control delete, ABS delete, SRS delete.. Plus other random stuff.
you don't need that rtv on the metal gaskets
These were delivered and installed...
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
