Page 405 of 892 FirstFirst ... 305355395403404405406407415455505 ... LastLast
Results 4,041 to 4,050 of 8916
  1. #4041
    May 2012
    Central Fl
    Found some rough looking glass headlights from a 94 stealth and robomodded them, looks much better now!
    1993 3000GT SL
    Mods: 95 front end, Robomodded Glass Headlights, VIS CF hood, Megan Racing Coilovers, relocated battery, short ram intake, VR4 Plenum, OBX LSD, OBX longtube headers, test pipe, 3SX underdrive crank pulley, Fidanza 9lb flywheel, Spec stage 3 clutch, solid lower engine mounts, 80a poly filled upper/trans mount, poly front sway bar bushings, Momo steering wheel, 3rd gen lifters, Konig 18" wheels, 4300k HIDs, gutted trunk, AC delete, PS delete, Cruise Control delete, ABS delete, SRS delete.. Plus other random stuff.
  2. The Following User Says Thank You to JGreenwood238 For This Useful Post:
  3. #4042
    Canaan NH
    Clean engine bay Mr Green Wood
  4. #4043
    Made myself an EMS version of the stock timing map using Greg's posted high octane timing map.
  5. #4044
    Quote Originally Posted by Markingtime View Post
    Skip a tooth?
    3 weeks after I bought it, it spit the belt. They were only bent slightly. The springs were strong enough to get a seal on them closed. I pressure tested them after it happened...
  6. #4045
    RTBOOST verified
    Florence, Wisconsin
    I bought another rear turbo so I can get that one freshened up & finally replace mine that's been blowing some oil through the I/C pipes...I also got some more materials to refinish some more brackets and whatnot.
  7. #4046
  8. The Following User Says Thank You to 2fnloud For This Useful Post:
  9. #4047
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Quote Originally Posted by Street_Chally73 View Post
    Shipped first thing this morning too!!
  10. #4048
    // Off the beaten path \\ Not Verified
    Ive been very busy finishing up school and just recently the car bug bit me hard. Decided to wash the car today for the first time in months and here's the result.
    Then I decided since I had some plastidip laying around I'd do the cowl.
    Before
    After
    I'm going to pull a part tomorrow to get new window motor/regulators since both mine went out and possibly get a 94 front end for later installment. I also plan on removing my sails on my next day off and plastidiping under them since they trim is fading.
    Stance Game Michael Myers
    19t RT/TT
    04 e60
    @Get_Like_M1ke
  11. #4049
    STL, MO
    Finally got my oil pressure gauge today, gonna put it in the car on Sunday and see where I sit with the pressure. Fingers crossed. If all goes well then it's time to crank out some work on the bad boy.
    1991 Stealth RT/TT
  12. #4050
    RTBOOST verified
    Florence, Wisconsin
    Now I'm going to pick up an overhaul kit & get it ready to bolt in.
