Page 400 of 892 FirstFirst ... 300350390398399400401402410450500 ... LastLast
Results 3,991 to 4,000 of 8916
  1. #3991
  2. #3992
    Oregon
    These Swedish and German only 3000GT OEM Seat Heater switches arrived the other day.
    This EU Spec, LHD, turn signal stalk with the headlight washer button on the end is inbound from Sweden at this time.
    This EU/UK Spec switch to adjust the aim height angle on the headlights from the cab is also inbound from Sweden at this time.
    Mark
    94 VR4
    There's no replacement for displacement.
  3. #3993
    Whoa! Blast from the past! Where ya been Mark?
  4. #3994
    Baaaaah! you suck Bill!
    Quote Originally Posted by Markingtime View Post
    Does the car support them buttons? I saw the heated seat buttons in Box's car. Would like that.
    Oregon
    Hi Bill,
    Been spending most of my time on foriegn Forums looking for the obscure OEM features we never got to add to my car. Just heard about the rare heated seats a month or so ago. Getting pretty good at using Google translate to get the gist of things in their posts. I feel like a world travler without the jet lag, although time zone differences do slow things down.
    Mr Lantern,
    The short answer is yes, but you need the whole system. Headlight washers need the nozzels that go in the bumper in front of the headlights, and the 1 gal resevoir with pump that mounts to the front crash bar. Heated seats of coarse need the heating elements themselves and I am still trying to get word on if they are just in the seat cushion or also in the back cushion. I intend to have both so I may need a second set of switches depending on the answer. I understand the headlights need the whole EU Spec headlight but may be able to get away with just the adjusting motors. I have a set of motors but have not pulled my headlights yet to see if they will bolt on. Only the high beams are powered up to be adjustable but there is speculation that the same could be done to the lows. I am negotiating for a set of EU headlights that will come with them so I will have enough motors and switches to try and make them all adjustable.
    One of the most valuable tips I have for people considering any of these upgrades is to be sure and get the OEM wire harness plugs that go with them that have enough wire attached for splicing. Makes everything much easier.
  6. The Following User Says Thank You to Markingtime For This Useful Post:
  7. #3996
    Twin Turbo verified
    Melbourne, Australia
    Washed it.
    Sent from my GT-I9300 using Tapatalk 2
    Waiting install
    Build Thread
  8. #3997
    RTBOOST verified
    Florence, Wisconsin
    I decided to polish out the fuel rails a little more, got my replacement injectors all assembled, & got the last shipment of my parts in from Cherry Hill for the fuel system overhaul U'm doing.
    Sent from the garage
  9. #3998
    St.Louis
    Fresh upgrade for my z11 frame.
  10. #3999
    Quote Originally Posted by Bloodlust182 View Post
    Sweet, make sure that shit welded good! Hire an expert or whatever.
  11. #4000
    Swapped out the scored exhaust cam and threw in an old flawless one.
