Page 395 of 892 FirstFirst ... 295345385393394395396397405445495 ... LastLast
Results 3,941 to 3,950 of 8916
  1. #3941
    I bought from from blacktop here on the forum. They are used and he had the boxes.
    I don't mind the gauges being metric as I have the LCD Boost controller which will give me the info I need in PSI. But it is nice to have these in the stock location as I can also set warning on them to let me know when something is going wrong lol.
  2. #3942
    One fix at a time verified
    Kansas
    Yeah I probably won't have a boost gauge at all. I don't need to stare at it when I know my boost control is solid plus I use the boost/knock screen all the time on the lcd bc. I need to get an external map sensor so I can read vacuum also.
  3. #3943
    The SMi gauges rock. They are basically Defi BF gauges without the tinted lenses. They are discontinued but you can get them from a couple vendors that have old stock. Once I complete my SMi set I'm going to sell my datalink PWH boost and fuel pressure gauges. Gotta be JDM tyte and all with matching JDM gauges.
  4. #3944
    Feb 2011
    Scottsbluff, NE
    Sent my actuators out to have 12 psi springs installed
    1995 Dodge Stealth R/T Turbo
  5. #3945
    STL, MO
    Got a little crazy, and moved it....kinda , with a lawn mowers help.
    1991 Stealth RT/TT
  6. #3946
  7. #3947
    guess that's one way to fix a dented pan.
  8. #3948
    Apr 2011
    Mid-April 2011.
    Monroe WI
    installed a new alternator, OPSS, as well as rebuilt the whole harness from scratch.... still no oil pressure reading from guage..
  9. #3949
    1993 rt/tt Not Verified
    wa state
    Nothing to the the stealth, but i DID tweak an '07 STI with; bigger turbo, 850 injectors, perrin FMIC & piping, fuel pump, plugs, and cobb tuner...
    ...i will never complain about doing the plugs or injectors on a 3s again
  10. #3950
    St.Louis
    sorry for the crappy quality. Paint layered out pretty well despite being a little cold.
