Well, I bought those SMI Gauges.
So wants to buy my Datalink gauges? :P
word to the wise installing the front addco bar.. The mounting brackets are slotted enough to get the bar installed in a position where a socket won't fit the top bolt. If I had to do it again I would place a socket with some tape inside on the top bolt when installing it to be sure I can tighten it.
I had everything snugged up, but came back and couldn't finish tightening the top bolt on one side. I had to remove both end links and pry the bar down to get to it. Fits good though on the stock end links. Couldn't really run a larger bar and have it fit with the stock mounts. Would be better if they included allen headed bolts, but I re-used the stock ones.
I was doing some searching on the subject last night, and D2 definitely have/had the same leaking issues. D2 is the main company and makes KSport.
The old Saner front sway bar is the same way. Last weekend I couldn't get a socket or wrench on the top bolt so I ended up taking out the bottom bolts, prying open the bracket, sliding the sway bar out, prying the bracket back up against the subframe, and then putting a socket on the top bolts. I'll reshape the brackets but won't install it on the Stealth until I know whether the Addco rear clears a CFDS and the axles when lowered. I don't see there being too much clearance but I don't want to run just one bar in the front.
... added a quick-connect to my battery connection today for easy plug-in charging. Been meaning to do that forever. Also checked parasitic draw, which shows 31mA. Better than I thought I'd see. Oh, took some pictures too.
Best in Show - NG07
2010 - 6G74/3.5L E16Gs - 688awhp/679awtq (Race+Meth)
2011 - 6G74/3.5L 68HTAs - 740awhp/762awtq (Race+Meth)
2013 - 6G74/3.5L MTC Stage4 - 908awhp/832awtq (Race+Meth) <--- Tuned by Ray Pampena
fixed it and drove it hard
