Rear coilovers were squeaking a little. Installed new Solid Bushings and greased em up good. Its nice
did some other misc.
Made this little heat sheild.
While I was fixing my window regulator and adjusting my window....
Damn! You did a nice job. How much does that stuff cost? I plan to tear my interior apart before too long and I'd like to do that while I'm at it.
I had 3 Stealth RT swirlies on it and a 15" steely. I took the 3 swirlies off, put the other 15" steelie back on front and two 2g na 3000GT wheels on back. I gave the swirlies to my cousin.
Talked to him about getting my car in the garage to try to get it road worthy.
Paul,
Read some stuff on here
I am not saying should buy from Don, be he was helpful answering my questions, and he products are not expensive either.
Not to dissing on the quality of FatMat, I have used it in my Saturn. We need to truly understand what the product is for, and that is to eliminate the resonance of the metal, you do not need to completely cover the surface to do that.
Plus the curved surface that is stamped into to area that he covered, will not resonate anywhere near as bad as the door skin it's self. Plus if you are trying to bring out the best sound you can out of your door, you need to seal off the openings the best that you can. to attempt to convert the door chamber into a speaker chamber.
Yes sealing it completely will be impossible, but the closer that you get the better the speaker will reproduce the lower frequencies.
Hope you find that info helpful
