Page 347 of 892 FirstFirst ... 247297337345346347348349357397447847 ... LastLast
Results 3,461 to 3,470 of 8916
  1. #3461
    Adjusted front alignment to non suck spec, greased rear wheel bearings.
    What did you set it to?
    Man vs 3/S verified
    Kingston, WA
    Set it to, "looks good and the steering wheel is straight".
    Maybe -2 degrees with a slight toe in.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  3. #3463
    That's my kind of alignment. Thats how I set teh Stealth everytime I pulled the trans.
  4. #3464
    Don't understand why you'd have to set the alignment after trans swap...
  5. #3465
    Becuase I didn't always pop the ball joint.
  6. #3466
    Man vs 3/S verified
    Kingston, WA
    Pull strut bolts.
  7. #3467
    don't understand
  8. #3468
    Drove the Stealth for the last time to the new owner's house. It's going to a good home as the new owner is a Honda service manager who is anal about his cars. The first thing he's going to do is change all fluids. I told him there was only 85 miles on the oil change and 4k miles on all gearboxes, but he's still changing them. I like his style.
    Finally down to one 3S...for now.
  9. #3469
    May 2012
    Central Fl
    Modified some Skunk2 coilovers that were for a galant to fit my SL. I needed a way to lower my front end since I've taken 100s of lbs off of it and the stock suspension was riding way too high. I had to take the adjustable perches to a machine shop to be bored slightly but other than that I did everything else with my angle grinder. Also installed an OBX limited slip differential. I still have to install the rear coilovers but my car is getting there.
    1993 3000GT SL
    Mods: 95 front end, Robomodded Glass Headlights, VIS CF hood, Megan Racing Coilovers, relocated battery, short ram intake, VR4 Plenum, OBX LSD, OBX longtube headers, test pipe, 3SX underdrive crank pulley, Fidanza 9lb flywheel, Spec stage 3 clutch, solid lower engine mounts, 80a poly filled upper/trans mount, poly front sway bar bushings, Momo steering wheel, 3rd gen lifters, Konig 18" wheels, 4300k HIDs, gutted trunk, AC delete, PS delete, Cruise Control delete, ABS delete, SRS delete.. Plus other random stuff.
  10. #3470
    painted some emblems out of boredom and installed the MM splitter. Also modified the short shifter to be closer to the wheel.
