Page 340 of 892 FirstFirst ... 240290330338339340341342350390440840 ... LastLast
Results 3,391 to 3,400 of 8916
  1. #3391
    Jan 2011
    az
    Started taking it apart
  2. #3392
    One fix at a time verified
    Kansas
    Looking for a new bumper. I hit the track last night, had issues with my clutch, overboosting, running lean as a result and knocking, and then to top it off someone did a hit and run on my car trashing the front bumper. It was a sad night. I didn't feel good at all.
  3. #3393
    Oct 2010
    Chicago-South burbs
    What did I do to my 3/s....Hmmmmmmm, Ohhhhh I know, I bought another one! lol ...I think that makes eight 3/S's in the stable.
  4. #3394
    Feb 2011
    Scottsbluff, NE
    That really sucks dude...
    1995 Dodge Stealth R/T Turbo
  5. #3395
    Kansas
    Quote Originally Posted by DK77 View Post
    Yeah I know. Someone just sold a 99 bumper earlier this week that would have been a perfect replacement. He said he would have made me a good deal on it too. I'm probably looking at spending at least $1200 between new parts and getting the front end repainted. I was planning on doing it eventually but was not ready for it right now.
  6. #3396
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
  7. #3397
    My cousin brought his girlfriend's Stealth over and I adjusted the TPS for them. Then we took the seats out of her Stealth and replaced them with the charcoal seats out of my Stealth. I then semi-placed the black leather interior in place in my Stealth. Didn't put the carpet in yet because it needs cleaned.
  8. #3398
    Jun 2011
    Sweden, Gothenburg
    replaced the mast + chucked out the aa box. weightsave yay! also painted heatshields and ic pipes with heatresistant paint
  9. #3399
    Andover, MN
    Yesterday I replaced the bad speedometer cable in my car with a new factory speedometer cable, fixed the alternator/power steering tensioner pulley issue and replaced serpentine belts again. I also replaced my antenna with an aftermarket rubber antenna.
    Last weekend I replaced the clutch slave, installed new SS braided clutch line, removed slave cylinder damper, added new hard line to the slave cylinder. Slave cylinder feels much smoother without damper and bleeding the line was much easier to do. I also installed Throttle Body Phenolic Spacer, upper intake phenolic spacer, gaskets, and installed my K&N bracket and K&N open Air Filter.
  10. #3400
    Jan 2011
    az
    Quote Originally Posted by Ange View Post
    Where is this as box located and what is its function?
