Page 336 of 892 FirstFirst ... 236286326334335336337338346386436836 ... LastLast
Results 3,351 to 3,360 of 8916
  1. #3351
    May 2012
    Houston, TX
    Soldered on my EVO MAF harness, and cleaned up the crusty booty-dew from the top of the trans where the slave cyl blew out. Also started measuring for aerocatch latches.
    Waiting on Dejon intake runners (should be in this week) then I can reassemble and drive again.
    '91 3000GT VR-4 Silly car, get down from there. You're not a plane. You don't even have wings.
    '03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
  2. #3352
    Banned J. Fast's Avatar
    First logged 3rd gear pull...
    NO timing in this and work to do on spool up fuel but it's progress and potential
    Step by step you'll get there. Bet your ass you can run high 20's / low 30 psi boost on E-85 on big TD-05 turbos . I don't have any dyno numbers for my billet 20g's yet but I bet they're puttin down 750+ to the wheel at 30psi. The power is absolutely unreal! Big numbers will come from your setup in due time. Congrats on results. Turn up the wick!
  3. #3353
    I don't bite
    Southern IN
    You are running AEM right? Post up a VD graph. Would love to see how yours look!
  4. #3354
    Pueblo, CO
    thought about washing it, then closed the door and watched football.
  5. #3355
    May 2012
    Central Fl
    Haven't posted an update on my car on here for awhile, it's currently down with a broken axle and I'm using this as an opportunity to upgrade to a limited slip differential and second gen axles. Last week I added a hood prop from a 2g Eclipse since the stock hood struts could harm my CF hood. Also cleaned the engine bay a little and tinted my robomodded lexan headlights.
    1993 3000GT SL
    Mods: 95 front end, Robomodded Glass Headlights, VIS CF hood, Megan Racing Coilovers, relocated battery, short ram intake, VR4 Plenum, OBX LSD, OBX longtube headers, test pipe, 3SX underdrive crank pulley, Fidanza 9lb flywheel, Spec stage 3 clutch, solid lower engine mounts, 80a poly filled upper/trans mount, poly front sway bar bushings, Momo steering wheel, 3rd gen lifters, Konig 18" wheels, 4300k HIDs, gutted trunk, AC delete, PS delete, Cruise Control delete, ABS delete, SRS delete.. Plus other random stuff.
  6. #3356
    damn that's a clean bay for an n/a.
    p.s.
    alan, really...how many phantom posts exist in this thread? i'm at 40 per page, and i have two additional pages that i can't load.
  7. #3357
    JNS Engineering verified
    San Jose, CA
    I was at forum defaults and had 8 pages that wouldn't load.
    Took mine out for pictures last night. I'm getting more proficient with the camera so hopefully I got some good shots.
  8. #3358
    What I did sunday
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Lots a new parts in mail for my 3/S.... Might have arrived already, hope so!
  10. #3360
    Apr 2011
    Mid-April 2011.
    Monroe WI
    New oil cap (I apologize for the irt, I have not given my enginr bay much love lately.
    Half of my HID kit and some 3mm spacers
