Page 303 of 892 FirstFirst ... 203253293301302303304305313353403803 ... LastLast
Results 3,021 to 3,030 of 8916
  1. #3021
    Started the 60k, just waiting on parts now.
  2. #3022
    you know you like it Not Verified
    Sacramento CA
    Wrote down my mileage for insurance purposes... 75,400 Miles
  3. #3023
    Sep 2011
    Missouri/ north Dakota
    Installed my hoop spoiler. Quite the job but looks great
  4. #3024
    Delaware
    Found out was caused Todd's two engines to blow. And it has nothing to do with Methanol Injection or the amount of it we spray(well, almost)...
    Jason
  5. #3025
    One fix at a time verified
    Kansas
    I drained my tank, filled it with 91, and had to drive about 15 miles to clean out the rest that was left in there. I almost thought it wasn't going to solve my misfiring issue but sure enough everything cleared up. For some reason I can't go past about 9 psi now because it cuts out so I think I may need to change out my fuel filter. Other than that I drove about 50 miles through some back road twisties doing 70+ through 30 mph turns and had a blast. It was extremely nice outside 70s. I'm almost leaning more and more towards getting a Spyder so I can drive with the top down. Lol.
  6. #3026
    VR-3747 :D Not Verified
    Dayton Ohio
    Jason you care to expand on your findings?
  7. #3027
    Feb 2011
    Scottsbluff, NE
    I would be very interested in what you found as well.
    1995 Dodge Stealth R/T Turbo
  8. #3028
    doing a little reading it seem to be pistons. (TOO MUCH POWA CAP'n)
    1996 GTO, Owner since 2003.
  9. #3029
    Jason
    Sorry, but why'd you even post?
    Got the block I will use for my 3.5L from a local, long time 3S'er. It's virtually identical to the block in my car, same year, same mileage... Even has the composite head gasket I scraped off mine long ago.
  10. #3030
    Delaware
    I posted that because its a fairly serious problem for people with piggy backs that don't have timing control that are making good power. Todds engines blew from excessive timing down low causing cylinder pressures high enough that the exh valves couldn't even open, collapsing a lifter and causing the cam to shover the rocker out of the way. several cars recently were dynod witth piggy backs, all gained 30+ hp down low by nearly halving the timing or literally halving it...
    Just something i myself and some others put together after breaking this last engine down with the intent of trying to find what caused the failure. Which was 4 pistons obliterated while being under 5k rpms and 50% throttle....
    Jason
