Page 291 of 892 FirstFirst ... 191241281289290291292293301341391791 ... LastLast
Results 2,901 to 2,910 of 8916
  1. #2901
    GTX2863R's with ATP .48 housings. 2871R power with 28RS spool.
    Jason
    Sweet! Billet wheels right?
    I killed bugs in it on the way to the store to get things that make me fat...
  3. #2903
    SKADOOSH!!! verified
    Prince George
    I hope it's beer you're referring to...
    Photobucket
  4. #2904
    Man vs 3/S verified
    Kingston, WA
    Autocrossed it, did terrible, about 2 seconds slower than normal, sucked.
    Need slicks and water injection.
  5. #2905
    May 2012
    Houston, TX
    Drove the car to lunch.
    Later, worked on these.
    By far the biggest pain in the ass soldering job I've ever worked on. Doing SMT LEDs without a board is... dumb.
    Preview with a gauge face. (Window is for BlackStealth's LCD boost controller.)
    '91 3000GT VR-4 Silly car, get down from there. You're not a plane. You don't even have wings.
    '03 G35 Sport Coupe Retains transmission and full warranty, even with VDC off!
  6. #2906
    Banned J. Fast's Avatar
    Quote Originally Posted by keo92stealth View Post
    How much material/weight do you think can be removed from inside the car?
    After it's gutted... 400lbs
  7. #2907
    Prince George
    Quote Originally Posted by james92tsi View Post
    How hard do you think this mod would be if I were to make the needle change colors as it moved?
  8. #2908
    May 2012
    Houston, TX
    They are probably using 3-chip LEDs and an RGB controller of some kind to control the mix of colors.
    Way more complex than what I am working on. 3-chip LEDs have 3 separate anodes and cathodes (one for each color). You'd really need to do those on boards (not on a scrap piece of gauge face plastic like I did) to keep the 3 traces separate.
    Then there is the minor detail of interfacing an RGB controller to the car so that you can change each needle color based on "whatever" each gauge is monitoring.
    Cool effect, though not really my cop of tea... and looks like a TON of work.
    The reason I am doing LED needles is that I'm changing the gauge backlighting to white LED. The clear plastic piece behind the gauge was designed for the stock bulbs and doesn't route enough light to the needles when you start deviating from stock bulbs. Hence bulding these LED rings to light the needles directly.
    Inspiration here: How to light gauge cluster with LED's - DSM Forums
    I am using different LED strips than those but the concept is the same.
  9. #2909
    Essex, UK
    Jason
    Had my eyes on those - I have some brand new 2860s with custom manifolds in my shed... just need to build the rest of the car up to take them, so will be watching your build thread if you make one Should be a fun car !
    Paul
  10. #2910
    Jason
    They look like they could eat small children!!
