Page 253 of 892 FirstFirst ... 153203243251252253254255263303353753 ... LastLast
Results 2,521 to 2,530 of 8916
  1. #2521
    Man vs 3/S verified
    Kingston, WA
    Bring it!
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  2. #2522
    What did I do to mine today? Replaced the IAC/ISC in the Straman last night. Less than 24 hours ago so that should count. Planning on back probing the ECU to see if I'm getting signal to injectors 1&3 (I already know I am not getting voltage to the coil packs).
  3. #2523
    Twin Turbo verified
    Melbourne, Australia
    Started it and went for a drive. Discovered what I suspect is a squeaking TOB
    Waiting install
    Build Thread
  4. #2524
    I remembered the fuel pump is failing...
  5. #2525
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Put it on a lift and did heavy inspecting. Dirty but checks out.
  6. #2526
    Still investigating why the Stealth running lights don't work. All relays good and no fuses are blown. Swapped relays between the VR-4 and Stealth with no luck.
    No night driving in the Stealth for awhile.
  7. #2527
    Change the headlight stalk.
  8. #2528
    Installed the TECH Performance front strut bar:
  9. #2529
    oct.2007...
    Cleveland, Ohio, United States
    those stut bars are awesome,the fitment looks phenomenal!
  10. #2530
    JNS Engineering verified
    San Jose, CA
    Steve, what is that box mounted where the battery should be? The Tec bar would interfere if a normal battery was there, right?
