Page 221 of 892 FirstFirst ... 121171211219220221222223231271321721 ... LastLast
Results 2,201 to 2,210 of 8916
  1. #2201
    Jan 2011
    az
    I got plates for the trailer today....Woo Hoo!!!!
    shit is legit blacked out. nice work
  2. #2202
    Feb 2011
    Scottsbluff, NE
    officially got my first engine pulled. I'll post up pics later
  3. #2203
    Mar 2012
    Delaware, Ohio
    I just finished polishing the upper , lower intake and the front valve cover. not a perfect mirror but descent enough , after school going to put everything back together including the front turbo, and any help is welcome.
  4. #2204
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    Quote Originally Posted by DK77 View Post
    Fun isnt it? I did my first pull and rebuild last winter.
  5. #2205
    A while back I bought 3SX center vent gauge plate. It's a total piece of shit. The biggest problem is the slot for the hazard switch that makes mounting it virtually impossible (it's too f'ing big!). Secondary issues are that the plate is actually 2 plates, held together by 2 flat head screws... The holes don't line up so the flat heads sit 'cocked'/angled... It looks terrible. Another secondary issue is that the 'plate' isn't sized quite correctly, so there are gaps on the outside of it when shoved into the dash.
    The day that I received it, I ordered 2 more plates from drweldin (3si). He had covered one of them in a 3M CF overlay, but if I didn't like it I bought a bare one too. He sized the slot for the hazard switch exactly as I would have (confirmed prior to purchase)... It allows you to shove the switch in and achieve a tiny bit of interference fit. The only issue is that it's kind of ugly because it forces the switch to stick out away from the plate. drweldin's plate fits the dash better than 3SX's does.
    So after looking at it for a bit last night, during lunch today, I modeled a bracket that I'm going to 3D print and use to mount the switch behind the plate. Hopefully I didn't mess up any dimensions
    That damn bracket has a lot of features that would have been a total PITA to produce any other way.
  6. #2206
    Never finishes any verified
    Wake Forest, NC
    Nice Work!!
    I just moved mine down to where the active exhaust switch used to be.....LOL I have my SAFC mounted in the vent now.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  7. #2207
    Nice Work!!
    Man, I don't even care if I have that switch. The problem is, every plate has that slot in it! A plate with 3 holes and no allocation for the switch would have been infinitely simpler.
    Hopefully it fits nice and tightly like I want. I was planning to use 3M DP420 to adhere the printed plastic to the back of the aluminum plate. I'll use sand paper to abrade the surface and alcohol to clean it. I'm open to any other suggestions though.
  8. #2208
    Wake Forest, NC
    I got 3sx stereo/3 gauge plate a while back. The stereo cutout is not a din slot by any means. You install your stereo stock and remove the trim ring. The plate goes over the radio which is fucking worthless if you have a flip down face head unit cause you can't open/drop the face then....... I'm glint to cut mine out to din slot size one day and install the stereo as it should be.
  9. #2209
    Man vs 3/S verified
    Kingston, WA
    Mine fit pretty well, have a flip down face, too. Works fine?
    Sent from my ADR6350 using Tapatalk
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  10. #2210
    Mar 2011
    Owosso, MI
    Came from UPS today
    [3SX Test-Pipe to Flow-master Delta 40 Series Custom Exhaust// 99' Lifters // Cold-Air Intake // MB Wheels 5X]
