Page 209 of 892 FirstFirst ... 109159199207208209210211219259309709 ... LastLast
Results 2,081 to 2,090 of 8916
  1. #2081
    Quote Originally Posted by Rakuny View Post
    Rear swaybar fitment?
    I need to hammer mine back more as well..
    http://img.photobucket.com/albums/v5...4-08172343.jpg
    http://img.photobucket.com/albums/v5...4-08172400.jpg
    Yep, TOTALLY acceptable for a bolt-on performance part............NOT. STILL hits at full droop on stock struts, but my suspension limits droop enough to clear.
    related things done this weekend:
    free AWS delete plugs: http://img.photobucket.com/albums/v5...4-08172132.jpg
    More adjustment range on the camber/caster plates: http://img.photobucket.com/albums/v5...4-08181831.jpg
  2. #2082
    Dad verified
    01 Apr 03 - Jokes on me
    NJ
    Not today, but on Friday, I finally pulled the engine and trans out. Have a ton of things to do ahead of me. Ordered an lcdboostcontroller setup, need to work on trans rebuild (synchros, billet end case, billet forks, reinforce bell housing, quaife lsd, and 300m output shaft), plus much more down the line.
  3. #2083
    West MI
    I had the weekend off and worked on the car as much as possible I...
    finished assembling the front sub frames
    Removed the dash
    deleted A/C including the part under the dash
    removed more interior brackets
    cut into my wiring and removed everything that I no longer need with the deletes I've done (CC, AA, AE, ECS, ABS, etc.) I am fully done with the interior and am pulling the fenders to continue into the engine bay tomorrow.
    I de-loomed the engine harness to ready it for mock up and tucking when the engine goes back in
    painted the engine block
    Tore down the dash to install gauges and new defroster vents
    And I accidentally left the camera sitting on the front fender
    UMG is coming up quick, starting to get concerned I won't be done in time...
  4. #2084
    you know you like it Not Verified
    Sacramento CA
    Good luck getting that thing recharged... I heard if you put a charger on it at 2 amps and ALSO hook up jumper cables from a good battery you can bring it back.
    I need to try with mine.
    Well I have a charger on it right now and it says it is taking a charge, it is a year old 'smart' charger and seems to be working with the optima just fine. What you described is how Optima recommends bringing the battery back from the dead if you have an older style charger.
  5. #2085
    West MI
    Make sure to fill out the lifetime warranty card and include pictures of the installation problems.. maybe they will revise it
    Edit: Does this mean you came up with an acceptable way to attach the swaybar endlinks to those adjustable LCA's? Care to share ?
  6. #2086
    Nope, AWS line bursting forwarded my time table, and next races are too close to keep R&Ding it. Running stock LCA's until after Road America, then I'll make a decision whether to try and get it done before NG or hold off until season ends.
  7. #2087
    94 3500gt vr2? verified
    NC
    It's taking a piss, lol
    Cut off about a 1/2" from the end and slid it back on. This will do for now.
    Bout time for new hoses
  8. #2088
    Man vs 3/S verified
    Kingston, WA
    Quote Originally Posted by Chris GTO TT View Post
    A charger alone wasn't enough for mine. It discharged over 2 days after charging for several....
    Sent from my ADR6350 using Tapatalk
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  9. #2089
    West MI
    Are you going to be at Gingerman memorial day weekend?
  10. #2090
    Probably won't be able to make that one, that weekend is already booked unless something frees up.
