Installed my GZP oil cooler.
Looking straight at it it's about the same size as stock.
But it's much thicker.
There really isn't much more room for a bigger core because of the IC piping without leaning it back a good bit and the efficiency suffering.
My review? I think it could use one or two more rows but it doesn't need much more. Without the SMIC there and this one being much thicker I'm pretty confident it will do the trick. I also like that there isn't banjo bolts. It seems like it will flow a good bit better than stock. After the install I let the car idle a bit and the oil pipe coming in was hot but the one coming out was nice and cool.
Even though I think it could be a little bigger I think it's a good buy at $200. Even better when you have 100 bucks in GZP gift certs.![]()
, swapped oil pressure sending unit, changed oil, replaced transfercase with a good one, fixed rear oil return leak with a new gasket, and some other odds/ends on the Stealth. It was a looong day.
have to fix little exhaust leak.. install headlights.. fix some ground wiring.
