Page 107 of 892 FirstFirst ... 75797105106107108109117157207607 ... LastLast
Results 1,061 to 1,070 of 8916
  1. #1061
    Apr 2011
    Mid-April 2011.
    Monroe WI
    race pipe shipped out today
  2. #1062
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Ecu showing codes 14 tps and 62 air induction system control sensor... Going to pull apart harness and look for any wires needing repaired. Gas, mileage ia suffering about 50-100 miles per tank. Performance lightly too. Any suggestions on this
  3. #1063
    Sep 2011
    Missouri/ north Dakota
    I installed a center console lid. Mine was cracked so I got another good condition used one.
  4. #1064
    Apr 2011
    Mid-April 2011.
    Monroe WI
    drove to work and back...like everyday....
    Found someone LOCAL to build me a manifold too...finally. Carma Performance.
  5. #1065
    Wrench Monkey Not Verified
    Rochester, NY
    Started dropping the rear subframe for reconditioning and to install a new steering pump. The brake and steering lines are my only obstacle at this point. Got 'em soaking in PB Blaster.
  6. #1066
    Drove to work due to the truck is in the shop...
    Got surrounded by mustangs on the way home. I think they where Mares due to the lack of balls!
  7. #1067
    Easton
    Found out which wire I need to ground to dim my gauges with the stock switch. Went to test it to make sure the gauges maintain power during cranking anddddddd no start. It has 11.5 volts before cranking according to the sm3. Key on works, Ac, stereo works, just nothing when I try to crank. Just a relay clicking on the DS footwell. I was so close to being happy tonight then the GT ruins everything.
  8. #1068
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Check nuetral safety switch, and theres a small tab on starter, often gets knocked loose on mitsubishi's...check that too.
  9. #1069
    Appalachian Paradise
    Re-assembled my interior.
  10. #1070
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Unplugged ECS computer, now about to remove caps as well. ECS is left in sport mode....
    Installed my 3 inch test pipe yesterday...didn't have gaskets laying around like i thought i did, so got some today and i am about to install them so no more nasty leaky ness.
