Page 103 of 892 FirstFirst ... 35393101102103104105113153203603 ... LastLast
Results 1,021 to 1,030 of 8916
  1. #1021
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Cold day in TN for the time of year, low 60's high 50's. car refused to get to operating temp. temp guage read about 3-4 tick marks and wouldn't go any warmer....so preparing it for winter.
    Making harness w\ switch for radiator fans
    Installing Heater Core hoses (I was freezing my butt off all day in the car)
    Adding a thermostat. Will help with the Temp problem.
    My Aluminum Radiator works Too good
  2. #1022
    SKADOOSH!!! verified
    Prince George
    "Tried" to put coolant into mine after changing out the oil pump and fixing the seals on the water pump, only for it to end up on the damn floor. I then proceeded to release the rage of 10,000 suns, slam my hood shut as hard as I could, push the car outside, and list it for $3,000...
    Photobucket
  3. #1023
    Wrench Monkey Not Verified
    Rochester, NY
    Drove the shit out of it in the rain.
  4. #1024
    Twin Turbo verified
    Melbourne, Australia
    Drove it to work like I do every day.......think to myself I must have one of the most reliable 3S's around
    Waiting install
    Build Thread
  5. #1025
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Mines pretty reliable...It has yet to break anything on me or leave me stranded...only problems it has are pre-exsisting conditions...such as dying trans, leaky radiator and a slipping clutch (autozone clutches are shit idk why anyone would think its a good idea) when i got the car, and then cosmetic things.
    23X,XXX on chassis and trans, Engine about 40k now...from factory, not rebuilt. It's so queit, loudest noise on it is my injectors pulsing.
  6. #1026
    Man vs 3/S verified
    Kingston, WA
    THIS!!!
    Also, got my E-cutout installed further back inline with the stock catback (stock catback is stainless, btw) sounds great, doesnt rumble the entire car like when it was in the test pipe area.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  7. #1027
    One fix at a time verified
    Kansas
    I pulled the battery relocation, rest of the 3SX dual pump/dual feed fuel kit, ARC-2, Blitz SBC-iD, all the aftermarket gauge sensors, triple pod, CFDS, and fuel pump hotwire. Just a few things left to finish.
  8. #1028
    Bought her some parts.
  9. #1029
    Fixed my no, click click no start problem that's been getting worse for years. Ignition switch was the issue pretty easy to change out. Hooked up my recently acquired apexi ITC. I turned down my timing and turned the boost up to 15psi. Still need to tune it and get it dialed in. Ah no more having to run waste gate on 93 pump. yea 780's are just a bit to big when I'm not on E85.
    Most powerful 13T car in the world @501awhp, PTE 780CC injectors, AFPR, E85, Greddy Profec B, 3.5" Granatelli MAF, MAFT, SS Headers and O2 housings front, 3SX downpipe, CRX racing FMIC, Dejon intake pipes, Ground Controls, Maximal adjustable rear control arms, Maximal TC Brace, Poly front and rear mounts, Vacuum Reduction, EGR block off plate, Hot Wired Walbro 255 and inline Walbro 255, Southbend stage 3 clutch, Slotted and vented rotors, SAFCII, Turbo XS BOV, 3SX FP hotwire, Seatle Short Shifter, Jackhammer timing gears: Best 1/4 mile 12.33 at 114.9 mph 1.79 60ft.
  10. #1030
    Quote Originally Posted by vr3.9 View Post
    So you're the one who snagged that!
