Page 10 of 892 FirstFirst ... 891011122060110510 ... LastLast
Results 91 to 100 of 8916
  1. #91
    sounds great....but you won't run into problems until you pass the 700whp mark. and that's probably pushing the limits on 3.0L with 16g's. only reason i got a 4-bolt was for a stroker. only reason i'm going with a stroker is because my 2-bolt has a cast crank. if it didn't; i wouldn't give a flip. i'm also shooting for the 550-600 range; but i'm not going to tune to the edge. 1 count of knock on pump & then turn down the boost 2 psi; and i'll never touch it again.
    p.s.
    what i did today was install the greatest looking stock tt plenum in the history of this platform.
  2. #92
    I AM IMPORT POWER
    Driving Vicki Crazy
    p.s.
    It's not the HP, it's the TQ. At around 700 ft lbs the 2 bolt girdle gives way.
    -Chris
  3. #93
    I AM IMPORT POWER
    Driving Vicki Crazy
    And what did I do to my VR4 today? Removed the clutch off vacuum, as the master has developed a leak and was making my idle high.
    -Chris
  4. #94
    SoSoCal verified
    I picked up my two car 3S car hauler in palm Springs and moved it to San Diego and stopped by dmv to register it.
  5. #95
    SoSoCal verified
    sounds great....but you won't run into problems until you pass the 700whp, Mark.
    His name is Michael btw
  6. #96
    Quote Originally Posted by DuTTch View Post
    drunk off your ass again?
  7. #97
    SoSoCal verified
    Its still early
  8. #98
    Riding topless!! verified
    Owned 8 3s since 2005.
    Corpus Christi
    My 3.0 is a 92 2 bolt. It's in excellent condition with only 57k. I just don't feel comfortable pushing it hard. I'd rather it go to someone that can cherish it at stock to moderate levels.
    I ended up up with a brand new built motor.
  9. #99
    Quote Originally Posted by Gearheadvr4 View Post
    i would happily have run that with 16g's; provided it had a forged crank. mine didn't.
  10. #100
    SKADOOSH!!! verified
    Prince George
    I finally started going on the quad pod again, hopefully to have it finished by Monday.
    If you're rockin' some ARP's isn't the 2 bolt just as tough to a degree?
    Photobucket
