Ah, Ok. Im going to tear it apart tomorrow see if I cant figure out whats going on. Ill keep all this in mind. Thanks guys.
I tried the pressure test, but failed because my old beat up pump isnt good enough to pump enough air in. I can hear a slight leak from the intake/TB area. Cant seem to find it because of the damn pump. About to go to check some out at WalMart. I decided yo pull off the ECU checked the caps and theyre fine. I did discover however, that one of those electronic solenoids that on the firewall across from the TB ticks when I hit the throttle. Ive been thinking it was the lifters but its defiantly the left solenoid, of the two vertical ones, if youre looking at it from the front. Could that be my culprit? I looked on the chart on the hood, it seams logical, yet I dont know what it actually does though.
I would say do a vacuum reduction and just get rid of all of those solenoids. When you're doing the pressure test, use a spray bottle with soapy water to help find leaks
Didnt think about the soapy water. lol. Wheres my common sense today.
So with the aid of some soapy water:
My idle screw is leaking as well as the rear turbo pipe. Pulled them both out and the o rings look old, Ill replace them anyway.
To solve yourself a world of problems, rid yourself of the rats-nest of vacuum lines in there. take off the hard lines on top of the throttle body, remove the solenoid rack, and any corresponding vacuum lines. All you need to be running is one to your fuel pressure regulator (I use the one on the back of the plenum) your waste gates (I use the one on top of the throttle body closest to the front of the car) and your blow off valve (The one on the front of the plenum) As for the problem of waste gate boost levels, you can temporarily use a small hose clamp to squeeze the internal diameter of the vacuum lines to the desired boost level (You should still pick up a controller though)
For EGR, if you have it. You can use the plates on the pipe from the rear O2 housing to the plenum, cut off the piping from the base plates and weld the holes shut using a bolt or some metal doweling for a filler. Making the plate for the valve itself is very easy, just trace it out according to the valve.
Noted. I may do that.
Update, I replaced the o ring on the BIS and put some JB Weld in the groove of the rear turbo pipe to push out the o ring towards the wall more. Tested it on a warm engine. And did a few runs on a nice straight above my house, it started not doing anything acting just like it should. But after the second run it developed the problems again. It runs better though seems to die at high boost, and it has that sputter again.More like a jerk. I had a hose off the EGR one time that produced a similar sputter but it was consistent, this one it not. It mainly does it at low to mid rpms in gears 3rd and up. Going flat out it doesnt sputter but it still dies at the top end 5k and up. Though its closer. But in my subdivision I put in 3rd at 2k rpms it disnt sputter, 4th at 1500 rpms and it didnt sputter but it did when I put it back at 2k rpms in 3rd. Put it back in forth and it sputtered. WTF?
Id do that vacuum deletion now but I m not so sure about putting a clamp on a hose to act as a boost controller. Though I may buy one from 3SX. Ill look up the vacuum deletion some more and see.
this still kinda sounds like spark blowout.
I did just get some NGKs around Xmas, stock gap with no mods thatd mess that up. And MSD wires with that, I might add.
