I have decided to completely redo everything basically for my new setup, so the only reason im selling these parts is to upgrade, they are all in mint/like new condition.
1) I need a different design on my endtanks this year so i am selling my front mount. This is a garrett core, and for those of you that dont know the best air to air cores available.
It measures 24x12x3.5 (just the core) with 2.5'' in/out pipes coming straight out.
Saying this thing is awesome is an understatement. It managed to keep the intake temps in check with the 9b's pumping out 20+ psi.
I can leave the pipes the way they are, or cut it back down to 3'' long pipes on each side and bead roll them like a normal IC.
$500 shipped and its yours
2)Next up is my 9b's with manifolds, o2 housings, and lines all still attached and ready to bolt on. These have served me well, made great power/torque consistantly. Never a leak, no smoke out of the exhaust, and if you can fit your fingers in there to spin them, they still feel like new. They were taken off with a little over 70k miles on them (dont remember the exact number).
They will come with oil feed and returns still attached, as well as all the coolant lines. None of them are bent or cut, they are ready to bolt right in.
Looking to get $300 shipped out of them
3) I have the line I first had made as for the rubber clutch line replacement, it is the right size and fittings, it just doesnt have the plastic coating on it they normally come with, but otherwise still a brand new stainless line.
$25 shipped takes it.
4) I will be making an aluminum cell this year, so i wont be needing the stock tank. It has a little surface rust on the top, but is very clean underneath. Not much else to descibe about a gas tank.
$50+ shipping
5) Stock sending unit. A little dirty, but solid. All wiring is intact, and never broken. The nut on the feed line is a little worn, but a wrench still holds it fine. Still has the seal on it, but the pump has been removed.
$95 shipped for it
Also got a bunch of random parts i've pulled out, if you see something you need let me know.
Paypal thebird65@aol.com
-Austin@STM
