I don't know how to add this to the how to section, but if a mod knows, please tell me.
1. First step is to pull the door panel. There are excellent guides elsewhere and it's almost self explanatory.
2. Gather your tools. Only very basic tools are needed. 10mm socket, #3 phillips screw bit, and a screwdriver or long needle nose for clips.
3. Remove the 2 10mm bolts holding the door handle on.
4. Remove the harness for the lock cylinder.
5. Start removing the small metal leads from the clips on the door handle and lock cylinder. Be careful since they can be brittle just pop the clip to the side and pull out the lead.
6. If you need to replace or check the switch then remove to two #3 screws form the top and bottom. They can be tricky to reach. Remember the wire harness on the bottom and the clip to the metal lead.
7. Next remove the door handle. Lift up the handle and slide the assembly slightly back and up. Be careful with the wire harness coming out of the lock cylinder. This needs finesse not brute force. You can leave the harness in the door if it is not damaged. You will need to unclip the retaining ring from the lock. 1st and 2nd gen setups have a different style lock. When removing the door handle you can leave the lock in the door handle or unclip the lock cylinder from the door handle and leave it in place. (I removed mine to repair the harness and change the locks.)
8. Use the screwdriver ( or some long needlenose to remove the clips from the lick cylinder harness. Take care and try not to break them. You'll thank yourself later during reassembly. There are 3 clips.
