Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
Thread: Aeromotive Stealth Fuel Pumps, E-85 compliant and flow 350 LPH at 12.5V
    1993 rt/tt Not Verified
    wa state
    Quote Originally Posted by Import Power View Post
    I run E95M5 and 160lb injs using 4 pumps and -8an. Many people over size their fuel lines.
    -Chris
    yeowsa...1,680cc injectors, what does one use to control them puppies?!?
    the BOSS of jellow supporter
    May 2005
    Dairyland
    I guess I will be one of them. what are the side effects of running possibly oversized fuel lines? I wanna go -10an (dual feed -6an fuel rails) with two of these pumps. I haven't decided on fuel injectors yet.
    i wouldn't think -10an would be oversize with 1600cc injectors on e95. -12an, sure, but -10 doesn't seem like a big oversize. DSM guys seem to use -10an upgrades quite frequently.
  4. #24
    I AM IMPORT POWER
    Driving Vicki Crazy
    Quote Originally Posted by wingnut View Post
    AEM series 1. I have idle set around 1500 to make things easier. It starts and purs right at 1500, no problems.
    -Chris
  5. #25
    I AM IMPORT POWER
    Driving Vicki Crazy
    Quote Originally Posted by a2j View Post
    Running out of line pressure.
    -Chris
  6. #26
    I AM IMPORT POWER
    Driving Vicki Crazy
    Has nothing to do with the injectors you run.
    -Chris
  7. #27
    -Chris
    Sorta like running IC piping that's 4" on 9b's?
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    -Chris
    What type of injectors are you using IPO? Did you have to bump the idle like that because of batt offset or something? You ever tried using a magnetic field booster / voltage balance bar on big injectors so you can keep the idle at 850-900? Some of the new fuel injector technology out there such as T-1 Racings Injector Dynamics Injectors idle really really nice, they're balanced soo sweet and purr at 900rpm.
    ID's dem's some badass injectors!
  9. #29
    I AM IMPORT POWER
    Driving Vicki Crazy
    Kinda like 9bs on a 4.0L engine. The pump just can't fill the lines.
    Look how much power, and safely, has been made on STOCK fuel lines. The stock feed is -5AN.
    So many people back in the day wanted 1000CC inj when they needed 550s, just so they can say I got XXX injectors. Just like a stock NA car owner saying, "I got a stage 4 clutch! SO WHAT?!
    Now everyone wants -10 and -12 fuel lines.
    -Chris
  10. #30
    I AM IMPORT POWER
    Driving Vicki Crazy
    They are based off of Ford 160 lb injectors. Bought from Advanced Fuel Injection off Ebay for CHEAP!
    -Chris
