Results 1 to 10 of 11
Thread: Should I use turbo coolant lines or does it not really matter?
    Pueblo, CO
    I am currently not using them, but was wondering if it will hurt my 19t's or does it not matter?
    Warner Robins, GA
    IMHO coolant lines should always be used. There is just way too much heat generated in the turbo, especially on the exhaust side to not provide all the cooling you can. No OEM will spend money on parts if not absolutely necessary. So, if the turbo has coolant lines, they must be absolutely necessary. Just my 1.5 cents worth.
    the BOSS of jellow supporter Feedback Score 0 a2j's Avatar
    May 2005
    Dairyland
    Quote Originally Posted by BaadVR4 View Post
    heat kills. so why risk it?
    Those, who stand for nothing, will fall for anything.
    On the Internet you can be anything you want. It's strange that so many people choose to be stupid.
    Dallas TX
    If you have 19T's, then it still means you are using very small headers with a small exit that heats up much faster than a TD05 setup. If you had TD05's and were running 17-18psi, I'd say you could probably get away with it long term. Smaller turbos though, I wouldn't risk it, and definitely not at higher boost levels.
    Forum User supporter Feedback Score 5 (100%)
    Oct 2010
    Rosemead,Ca
    I have ran a set of 16T's without water lines for a year or so. never had a problem. but I still ended up connecting them. I wouldn't risk it
    Feedback Score 6 (100%)
    not much reason not to on stock housing turbos.
    Pueblo, CO
    but im not stock
    but im not stock
    you have stock housing turbos.
    Prince George
    Use them! For the price, you'd be better off getting some than replacing your turbos. With such a short header and small housing the turbos don't dissipate the heat very well which will increase the risk of the oil baking onto the bearing surfaces which is no good!
    Photobucket
    I do and I would
