Was working on installing my power folding mirrors and things were acting funny in the switch. I took it apart to map out the pins (I could have found the info but I was curious on the internals). Then I realized, the pins that were soldered to the connector and the board had cracked solder joints. Once I removed and fixed the joints all was well.
Just a fair warning if your switch is acting funny. Not sure if this will be common but it might save some debugging time. That is, assuming you read this
-Antoni
