Results 1 to 10 of 11
Thread: car suddenly speeds up
    Dec 2010
    I am having another problem with my 91 Stealth ES, when accelerating the car will suddenly get a boost of acceleration even though my foot is steady on the gas pedal. It just seems to pick up like its had a sudden boost of power.
    I hope that makes sense, any ideas?
    California
    I know if your cruise control is malfunctioning it can cause your car to suddenly speed up as you described, as it's happened to me before. Simple fix though, replace cracked/ torn vacuum lines or disable the system all together. However, you said you have an ES and I can't remember if those have cruise control or not. If your car does I'd start there though.
    1995 3000GT VR-4: 15g turbos, MBC, FMIC, custom exhaust/ high flow cat, vacuum reduction, 550cc injectors, solid motor mounts, megan coilovers, front strut bar, retrofitted TSX HIDs into 99 headlamps, along with a few other things.
    2003 350Z Touring : My DD. JWT pop charger, motordyne plenum spacer.
    Melbourne, Australia
    Did you buy Toyota?
  4. The Following 3 Users Say Thank You to GTOJOE For This Useful Post:
  5. #4
    Southernmost 3S Owner supporter Feedback Score 0 93STLTH's Avatar
    Key Largo, FL
    You should check the throttle cable and make sure it's not binding. Disconnect it from the throttle body and see if it moves in and out with ease. If it's catching at some point, it might slowly work it's way out while your driving, causing the unexpected speed up.
    2013 NG: 1st place, FWD Drags
  6. #5
    Dec 2010
    Quote Originally Posted by zvr4 View Post
    I don't even know if the cruise control is even working I have never used it.
  7. #6
    Dec 2010
    Quote Originally Posted by 93STLTH View Post
    I will check this out thanks.
  8. #7
    California
    Quote Originally Posted by cdc View Post
    That's exactly my point your cruise control may be broken. It connects up to your throttle so if it's malfunctioning it can cause many issues.
  9. #8
    Stress free wheel gap. Not Verified Feedback Score 0 YoshiBishi's Avatar
    Jan 2011
    Morrisville, NC
    Did you buy Toyota?
    Beat me to it!
  10. #9
    Dec 2010
    I have not had the chance to look at the car yet however I have a another problem I think is related to this problem.
    When I first start the car in the morning I have to drive up a hill on my way to work, this road is a 55 speed limit and I am lucky to get to 30mph as the car will not accelerate up the hill even when I floor the accelerator. If I unplug the MAF the car will go up the hill no problem, I have tried a different MAF with the same number but it still does the same thing with the MAF plugged in.
    Any ideas?
  11. #10
    DR750's cool kid club! Feedback Score 0 TT Eric's Avatar
    Ottawa
    It happened to me when I got those DR750's installed.
    Could it be the voltage on the TPS that is unstable ?
    Eric
    DR750's, DR stage III heads, DR Boost cooler stage 2, Denso 660cc, TE37SL +273'S Z1 , KWv3, Stedebani suspension buschings, SCE 13'' Stoptech, 2G rear brakes, Forged shortblock, 3SX cam gears, SCE racing oil pan, PST CFDS, RPS 6 puck, RPS Flywheel, ETS FMIC, 3'' custom quad tips catback, new leather seats heated, SCE center diff, Quaife, brand new tranny/tcase, Billet casings, Chrome ECU, Swaintech...
