Results 1 to 10 of 30
Thread: Smoke at idle
    I Kill Threads verified
    Wichita KS
    Smoke at idle
    I recently put new turbo's, injectors, walbro and an emanage blue in and now the car smokes at idle, but no other time its seems. Tomorrow I'm going to be followed around by a friend and verify that it only smokes at idle.
    It's a white smoke but it smells like oil so I'm not really sure what the cause is. I was going to replace my pcv valve because I read of it causing this sometimes, but also having leaking vss will cause the same problem from what I read.
    When I took my pcv valve off to test it, I really couldn't blow through any direction with a noticeable amount of air coming out the other side. This included blowing into the threaded side, in which an amount of air so small came out that I don't know if I was imagining it or not, and through the nipple side, which no air came out of. It also didn't rattle for a while until I just kept shaking it and it finally started but didn't do it with ease.
    The turbo's have a little shaft play but aren't touching the walls of the turbo. And since I've put all this stuff in I've only boosted once when trying to tune and that was only 9 psi peak so I don't believe I ruined anything.
    What's the most likely culprit? Should I order a new PCV valve first?
    1992 3000GT VR-4
    Newark, DE
    Last time I did a search on smoke everything at idle points to VSS. It is hard to tell smoke color, when mine was blowing smoke @ decel from boost I was sure it was white, but after doing much reading on different smoke and colors and reasons I realized mine was from boost getting in crankcase. It does sound like your PCV is gunked up, it should rattle easy, and can be cleaned, but its also cheap to get a new one. People bitch about the PCV being inadequate but there is a consensus to stick with OEM when you get one.
    Your PCV valve needs either replaced, or cleaned out with a solvent of some sort. That could be your entire issue, but I had smoke at idle from VSS... Had them replaced, and had less smoke for a while, but I think one of the oil rings had a nick or something, it got kinda bad again.
    The PCV valve is defiantly not working right. I honestly would recommend everybody that doesn't have to deal with getting tested for emissions do away with this crappy PCV system. It seems to be the root of all evil with these cars. Vent the crank case to catch can or to atmosphere.
    Wichita KS
    Well I don't have emissions so should I just get a catch can instead of replacing the valve? And what about venting to atmosphere, I haven't heard about this way.
    I figure I'll make up my mind tomorrow about what to do so I can get back to tuning the car instead of being fearful of the smoke.
    Oh and I forgot to add in the first post but it doesn't seem to be burning anything at all when checking the oil and coolant. But of course it could be such a small amount the difference isn't noticeable.
    West Islip, NY
    From what i've read you'll smoke at idle if you vent to atmosphere or a catch can since the PCV allows the VSS to seal.
    I've got the smoke at idle issue as well, and I have replaced my PCV with a brand new OEM one, and it still happens(Though original smoke was from a turbo that self destructed, but it was smoke ALL the time, like, REAL bad..), so I think it might be VSS. It also only happens when cold, or after a period of driving at a low RPM(like idling in first in a parking lot or bad traffic).
    1991 Dodge Stealth ES
    - Sold
    Sold.
    Jan 2011
    mine will smoke if i rev it up. it only smokes when i let off tho. it smokes bad when i let off but it doesnt smoke or if it does very little while at idle. this may be a dumb question but was is vss? is it variable speed sensor? if so how can u tell if its what is bad? sorry to thread jack
    vss = valve stem seals
    You shouldn't smoke at idle with no vacuum if you have brand new vss, but I bet with age they'd start to leak and cause smoke. I'd keep the PCV, but run a catchcan.
    Wichita KS
    Can you show me where some info on running a catch can and PCV so I can look into that avenue Doc?
    Fluffy, I haven't read of anyone smoking after replacing their PCV valve when it was actually the culprit with a catch can or similar.
    Am I Sade to drive it while it smokes like this? Other then this issue it runs perfectly fine.
    You simply mount a catch can near the t-stat housing, and run a line from the PCV valve into the catch can, and run a line to the lower intake manifold. You can also add a mini catch-can (plastic fuel filter or something) on the line from the rear valve cover to the intake bubble if you want, just to keep the rear turbo from sucking as much oil.
    It's not great on the seals and rings if you have a totally bad PCV system, but I'm sure thousands of 3S owners do it every day without knowing any better with no major issues.
