I am looking for someone who knows what the original OEM valve stems on our cars are made of.. mines a 96 if it helps..
The valves themselves or do you mean the valve guides?
Without knowing the direct material, I'm sure the valves are a stainless alloy of some sort.
Ask "ondonti" from 3si. Not sure if he is one this forum too. If anyone would know, he would.
