My car ran like shit without the injector adaptor fitted.
LMK when that EMU arrives there safely
I had the same mindset for the intake pipes and still do. This is what I used:
The pipe that you linked costs $70 less though haha!
yeah I don't see why they want so much for that joiner pipe, maybe it is really hard to
make the taper. Hell if I was making one I'd just roll some sheet metal and weld a seam
down one end.
I've found some posts in the other sites wiki that say a 4" O.D. pipe WILL fit in the stock
bubble. So that pipe I found should work and be really cheap. I'll grab some t-bolt clamps
from them and that will help the bubble conform to the shape I want.
I also like how short that coupler will be, I can use the biggest filter possible in the stock
location.
I'll let you know when it gets here
You might have a lucrative idea for an inexpensive "joiner pipe" as you called it. I guess nobody has really looked into it since most go for the twin intakes. Also, you would think that the 4" would fit since the LS6 MAF fits fine [Idk how snug though]. My K&N was 7" btw just in case you were visually curious about your plans for 9:
not trying to throw your thread on a tangent!
nope thanks for the posts!
Yep, the LS6 fits and the 92MM arc 2 maf fits.
The 9" should work well, in additional to my "joiner" pipe being a lot shorter, I have the abs delete, so those lines aren't there.
There is no real restriction in the stock t at any power level I'm going to reach. Matt at DR made about 970AWHP through it. At that point he switched to independent 3" intakes and gained somewhere around 30 HP IIRC.
If I am slightly off from the details I apologize, but the general idea is correct.
Keep us updated on how you like it and how the speed density works out!
Well I bit the bullet and got the greddy injector pack,emu complete harness and the af harness from frssport.
Sent from my DROIDX using Tapatalk
For the 'joiner pipe' I just used some PVC from the hardware store. Was like $4.
