i posted this on the other forum too but anyways... i just recently cleaned the iac following stealth316 procedures and i dont think i messed anything up. i put everything back on tightly too. after i put back the iac the car started but the idle was low on cold. i pulled it out of the garage as it started to warm up it stalled. i then got the car back in the garage and saw the bad rubber coupler that connects the ypipe to the tb, so i replaced that with a silicone one and tbolt clamps... now on cold start ups the car starts up and idles at 1200 rpm's ONLY FOR A ABOUT A FULL SECOND, then it stalls...
is there anything else i can check? fuel related problems?? i just made a pressure tester havent gotten an air compressor yet im going to borrow one from my friend tonight hopefully... but besides doing the leak test, what else could it be and what can i do? or was it most likely i messed up my iac somehow??
