Results 1 to 4 of 4
Thread: Affordable USB Powered 7" Touch Screen
    All you guys who are looking to get a touchscreen for a carputer and are looking for low price monitor, look no further. Its only a 100 bucks!!!!
    Proximus P16-40922 Mini 7 USB Touch Screen Monitor - 800 x 480, 500:1, USB 2.0, Black at TigerDirect.com
    Silver Spring, MD
    Don't get it. A friend of mine picked one up a while ago. The touch screen is very inaccurate and it isn't multi-touch. Also, when using as a second monitor, the touchscreen functions affect the primary monitor not the secondary. Plus no linux drivers, so you're stuck with Windows.
    MODS - DNP Intake with K&N Style Filter, Polished DOHC Throttle Body with Portmatched Plenum, Portmatched Intake and Exhuast Ports on Heads, Ported Intake Passages in Heads, Performance Valve Job (Street), 3SX WebCams Reground Cams, .20 Overbored Block/Pistons, 3SX Fed Spec Downpipe with Gutted Rear Pre-Cat, 3SX Stock Size Crank Pulley, BigTyla Ground Wires, MSD Spark Plug Wires, Seatlle92VR4's Hyper-Flex Polyurethane Motor, Ultimate Performance Strut Bars, 3SX Polyurethane Suspension Bushings, Shift Kit
    Quote Originally Posted by Dbeltran24 View Post
    I've got to ask, why the hell do you need multi-touch in a car? It's hard enough to reach down to the stereo console with single finger accuracy, let alone two or more. Plus, the only way to get multi-touch is to go capacitive, and that just adds expense to a screen that works just fine with a 5-wire resitive screen. Now, if that screen is inaccurate to begin with, I can't defend it. I didn't think they needed drivers for linux, and were just detected as input devices, like mice. Could be wrong, as I haven't used them with linux.
    THIS ITEM IS CURRENTLY UNAVAILABLE
    Looks like you can't get it anyway.
