Results 1 to 4 of 4
Thread: Fuel Tank Lines
    Never finishes any verified
    Wake Forest, NC
    Fuel Tank Lines
    So I think I may have mixed up my fuel tank lines when doing the rebuild on my stealth TT. the frame didn't come with a fuels tank so I used the one off of my 92 Stealth. I had to replace the main fuel line with braided hose as the hard-line was damaged. the plastic cover running under the passenger side to protect the fuels lines also keeps them straight. Well I had to remove all of it and I think I got my Fuel return and EVAP line mixed up. Every time I remove the fuel cap the tank is way over-pressurized. when I took the car to th gas station to put some gas in it I got about 1/2 a gallon in and it over flowed right out the fill. So I am assuming my vent lines are not connected right. I looked through the manual and couldn't find where they are labeled.
    Here is a pic of the lines from Stealth316:
    1: Fuel supply: replaced with braided lines
    2: Fuel return ????
    3: EVAP line ????
    4: Filler vent line
    Here are the lines on top of the tank "Thanks for the pic Austin"
    What exactly is the blue thing? One way valve???
    1: Evap Line ????
    2: Fuel return ????
    3: Filler vent line
    4: Fuel supply line
    Are these correct??
    I need to get under the car and make sure I have them hooked up correctly. Might be one of the many problems I am having fuel wise. It's funny that if they are hooked up incorrectly that the car still runs...
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Forum User supporter
    Oct 2010
    Rosemead,Ca
    Just looked at the tank i have on the floor. Yes you are correct with everything
    94 3500gt vr2? verified
    NC
    I'd have to look at mine and check.
    If you happen to need anything off the tank, I have 2 fuel tanks with pumps and all i need to get rid of
    you're welcome to either or all of it for free
    didnt you replace the filler neck?
    could be an issue with that. there are a cpl dif versions i think
    Wake Forest, NC
    I finally got around to checking the vent valve. Pulled the hose off going to the front of the car and the valve just started spurring out air from the tank. So the valve is good but somewhere underneath the car the vent line was kinked. I ran a new vent line and zip tied it to the filler neck. No more pressurized tank!!. I am still having issues filling the tank up all the way but I beleive it may be due to a bad float sender in the fuel pump assembly. Have to pull it out sometime and check it out.
