anytime someone other than myself assembled my engine i would be nervous. the machine shop may have done it right but the assembler??? since yo uhave tools why not mike the piston to bore dimensions, check bearing clearance, check thrush bearing clearance and make sure thrust bearings in correct and piston-rods are in correct direction.. and use the correct lube to torque the bolts
) Again I just wanted to know I built this engine start to finish.
