Page 11 of 43 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 422
Thread: SMIC vs FMIC
  1. #101
    Here are some ideas to improve cooling in general as mentioned before . (Also better aerodynamics)
    Vented hood: you want to have a bit of a lift in front of the vents so it creates a low pressure area behind it.
    (more air out = more air in) :
    Underbody: Some good designs.
    Front splitter: forces the air into the coolers (more air in = more air out)
    then there also the performance aspects, such as drag, down force, etc. etc
  2. #102
    Good info:
    The colors here actually indicate air velocity, but since air speed is related to pressure (Bernoulli affect) it gives you a general idea of the air pressure contours. Blue areas are areas of low airspeed (hence positive air pressure) and the red areas are low (or negative) air pressure. Notice that at the base and center of the windshield, you have hardly any air movement at all. In fact, in this area the air is actually moving backwards into the A/C intake vents that are at the base of the windshield. This is why the A/C vents are placed at this location, and that's why at high speeds, even with the air off, you can feel air flowing out of your A/C vents. The air is being forced into the vents at the windshield because the pressure there is higher than the pressure inside the cabin (which is close to atmospheric with the windows open).
  3. #103
    Also the front bumper design matters bigger openings (more air in = more air out)
    OEM designs 99´ wins .
  4. #104
    well, for the record I'm not a fan of venting back under the car....definitly prefer it to go out a vented hood (why I bought the Scoote II) and for the 5 hours I had it attached a LOT of heat came out of it.
    1996 GTO, Owner since 2003.
  5. #105
    yeah me neither but I also hate aftermarket hoods (due to the shitty fitment )
  6. #106
    and I´m also wondering how to make my vented ´widebody´ fenders functional
    interesting:http://www.s2ki.com/forums/index.php...ic=324009&st=0
  7. #107
  8. #108
    DR750's cool kid club!
    Ottawa
    I didn't read the whole thread cause I didn't catch it form the start. But from my experience, I was a true believer of the SMIC and didn't want to go FMIC.
    First I went from stock SMIC to DSMIC, then to Dejon SMIC, then Gene's SMIC and finnaly ended up with ETS FMIC at last. And now I can say that I should have gone right away for the ETS at first.
    From one set-up to another I was able to run more boost before getting knock each time, but when I went with ETS FMIC it made a huge step up front, I need to say I made some other mods in the same time, it could affect a bit the results, but all in all the FMIC was the makor mode and now it allows me to run a lot more boost on pump gas.
    The only downsides I saw with going to FMIC is to have lost a bit of spool-up* and some pressure pulsing at part throttle. If I was to make my car a lapping car, SMIC would have been a better choice, but for all other application FMIC is the way to go IMO.
    * As soon as I went with DR-ARC2, I gained back more spool-up then what I had lost before. Now I can almost say my turbos are spooling too fast for the car.
    Eric
    DR750's, DR stage III heads, DR Boost cooler stage 2, Denso 660cc, TE37SL +273'S Z1 , KWv3, Stedebani suspension buschings, SCE 13'' Stoptech, 2G rear brakes, Forged shortblock, 3SX cam gears, SCE racing oil pan, PST CFDS, RPS 6 puck, RPS Flywheel, ETS FMIC, 3'' custom quad tips catback, new leather seats heated, SCE center diff, Quaife, brand new tranny/tcase, Billet casings, Chrome ECU, Swaintech...
  9. The Following User Says Thank You to TT Eric For This Useful Post:
  10. #109
    I think the FMIC vs SMIC depate is more personal preference than anything else.
    +1 for ETS fmic
  11. #110
    but I truly feel ETS should have done dual inlet since they used core that big (26x12x3.5)..
    ie
    vs
