Hrmmmmm
Mine, if I mash it when I get 14-15counts of knock, it goes away immediately. I do usually just keep it out of the under 2k range.
Since the EMB is pre-ECU, you're timing will be more advanced than stock. I really can't imagine it being enough (unless you have ungodly huge injectors) to cause this much knock, especially if you're pulling 3-4 degrees.
PS, I should probably change my sig since I haven't run 18psi since NG. I lowered it to 15psi because of really bad spikes. Shitty boost controller. *grumblegrumble*
