i was asked to start a new thread for this. has anyone done this before? how about with separate front/back intakes?
i'm currently trying to find the best intake/anti-surge/BOV combination for my new setup which will:
1. prevent surge
2. be least complicated
3. be relatively inexpensive
4. not be excessively annoying
*edit--my post from elsewhere*
i'm going to a GM MAF in blow through (BOV immediately before the sensor). now i'm content to run open or recirc, but i'm not aware if there's any methods to keep it recirc w/o keeping the stock bubble. i get the impression that running recirc eliminates the need for "surge tubing" (which, as it was pointed out to me, is essentially a constant boost leak). i'm also looking to keep surge levels to a minimum. i'll be running an FMIC & a td05 kit; so i'm not sure that it's possible or even advisable to keep the stock bubble. i'm also unsure if it's better to get separate intakes for front/rear, or to stick to 1 combined intake. any suggestions/advice? i need to figure out what i want before i pull put down a couple hundred on a new intake.
