Results 1 to 10 of 11
Thread: DIY dress-up kit
    DIY dress-up kit
    what diameter/gauge of wire loom & silicone hose to i need to deck out my engine bay? how much length do i need?
    -thx.
    Charles Town, WV
    This is what I used, and had some leftovers. I don't have exact measurements, but it's less than the contents of this.
    1995 VR4 Coupe
    damn the work internet blocking pics
    Charles Town, WV
    10 ft - 3mm
    5 ft - 6mm
    2 ft - 10mm
    350* heat resistant, if that makes any difference
    and loom? 3/8"? 1/2"? 3/4"
    Owosso, MI
    I hope you are using black loom as the colored stuff looks really tacky.
    undecided. i may very well go with black. loom isn't something i'd need while doing the build (unlike silicone hose) so i'll hold off and see how it looks & then make a decision.
    be careful with the silicon tubing, most of it is too cheap and thin and collapses under heat and vacuum.
    use this if it doesn't; need to be purple:
    Silicone Boost Vacuum Hose
    If you want some hose let me know I can throw it in with your order before it ships, the stuff we have is the best I have ever seen, very flexible, doesn't collapse, and is easy to install but still holds very tight, its made by the same company that makes our couplers. Plus its only $1 per ft.
    -Austin
    And the list goes on...
    And for loom go black, it just doesn't look right in any other color.
