Results 1 to 10 of 17
Thread: balancer info needed for 500+ hp build
    this is mainly for those who are running 500+ hp setups, but is fair game for anyone who has experience with this product:
    Crank Pulley Harmonic Damper Balancer Non-OEM DOHC 3000GT/Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
    if anyone has this, has had it in the past, etc--let me know. good, bad, ugly? better or worse than stock? durability vs stock? etc.
    i am NOT going to run a solid pulley; so it's a choice between OEM and this. need some feedback.
    thx!
    -BOOSTTD- verified
    Elko, Nevada, United States
    Wondering the same thing. I'm about to pull the trigger on a new damper and would like some feedback on this subject as well.
    if you want aftermarket get it from rockauto:
    1995 MITSUBISHI 3000GT VR-4 Harmonic Balancer
    roger. and i would. i just wanted to hear feedback on this part.
    i would buy oem instead of those
    seize the carpe!
    stock crank pulley and stock flywheel.
    Quote Originally Posted by Lithium View Post
    stock crank pulley
    ATI , Fluidamp, IW or similar I would take anyday over OEM one . you get what you pay for right ?
    seize the carpe!
    Quote Originally Posted by mb7050 View Post
    I guess I should have been better with my post, With that much power you should run some type of dampened crank pulley. All the big boys run stock weight crank pulleys and flywheels to help the crank cope with the extreme stress. I remember there being a thread on "the site that shall not be said" about this exact issue. That being said I'm just under 500WHP and I run a Stock size lightweight 3SX crank pulley
    Never finishes any verified
    Wake Forest, NC
    I think he is looking for more detailed information like specific reasons to choose OEM over after-market.
    Like Lithium stated the dampener is really needed to remove the excess stress from the crank when pushing that much HP. It lessens and helps control the amount of vibration going into the crank. As to which one to choose "OEM vs After-market" I would want to say after-market but it depends on the compound they are using for the dampened. We all know the OEM ones are prone to falling apart, but that may just be due to age. If the Balancers are still in production then I would say you should be ok. If they are out of production then they have been sitting on a shelf somewhere for god only knows how long.
    I purchased a Stock Shift boot and it started to fall apart after a week. Come to find out it was one of those parts Mits stopped production on and it had been sitting in a hot warehouse for 10+ years. Might be the same issue with Stock balancers just falling apart after time.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    what we need is a quality balancer with reasonable price .
    all i know DORMAN falls apart 100x faster than oem and ATP @ 80$ well i cant expect much
