Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 136
Thread: Megan Racing Coilovers keep changing height as I drive.
  1. #111
    S Techs vs H techs
    S techs (1.5" drop in the front and a 1.3" drop in the rear)
    Front: 4.2 kg/mm / 235 lbs/in
    Rear: 2.8 kg/mm / 157 lbs/in
    H techs (0.9" drop in the front and a 0.7" drop in the rear)
    Front: 3.9 kg/mm / 218 lbs/in
    Rear: 2.6 kg/mm / 145 lbs/in
  2. #112
    it seems I have to chance my plans ...
  3. #113
    yeah...no farking way either of those would work with my car. i'm non-ecs to begin with, and i needed to RAISE the rear, not lower it.
  4. #114
  5. #115
    I've experienced the ride on Stock, S-Tech, Eibach, H-Tech,
    Hey man I´m thinking of trading my S techs for the eibachs because S techs are little too stiff and H tech ride little too high I´m thinking eibachs would be something beetween am i completely wrong here?
    Eibach (2811.140) Pro-kit Series
    variable rate,
    Front: 228 to 428lbs, 1.3" drop
    Rear: 154 to 228 lbs. 1.3" drop
  6. #116
    Banned J. Fast's Avatar
    I just don't think they level the car out that well. I guess if you let them settle by parking it on a hill with the gas tank empty it will look good. Remember that mfr's rate is only for the 1st inch of compression and they're progressive springs. Got any info on the wire diameter and spring composition differences of the Eibach vs Tein?
  7. #117
    I'm more concerned of the ride comfort, i would like to maintain stock like ride comfort and just slightly increased handling. I know I could mix the s techs and the h techs like Jimvr4 did to level out the car.
  8. #118
    I like that setup. How do you order half a set?
  9. #119
    you can´t you have to buy 2 full sets
  10. #120
    ...leaving you with a set of perfectly level ones; and set which rake the car something fierce.
