oh and I bought the HD´s and Eibach pro kit springs for the spyder will see. Wheels need to go tho
Struts :http://www.eshocks.com/bil_Ind.asp?VC=4Q53&SubChar=Q
Springs: http://motors.shop.ebay.com/i.html?_...506.m270.l1313
I'll take your wheels![]()
275 allaround +42 if I remember correctly.
Just eibach lowering springs and B6 (HD) struts.
371 $ for a set of 4 shocks/struts = almost free . If the combination does not work the way i want then its time to do something custom.
I got the eibachs from my friend (free / I gave him my S techs) and the 1.3 " drop is enough.
What exactly is the difference between the H and S techs?
Height?
Ride/rate?
__________________________________________________ ____________________
Tapatalk Bitches!![]()
S techs : Stiffer and lower about 1.5"
H techs : Not so stiff and lower about 1.0"
Stiffer does not handle better?
Or the H techs are a better suited spring rate for the ecs struts?
I am honestly thinking of attempting what DG is suggesting if I can get info on spring rates needed. I have the access to the tooling to customize the upper perch. Just need guidance on design...
I just started to take apart my rear struts and immediately noticed this , the shop botched the install and/or the S techs dont work with spyder smaller upper mounts, anyway no wonder the rear felt like shit
I though this could happen but 3sx tech said that the s techs do work with 1996 spyder (my first non ecs car)..
(1996 Spyder)
the upper strut mounts looks alot bigger in the coupe ( 1994 Coupe)
After Market Spring Rates:
JIC FLTA2 Series, Turbo AWD Front: 787 lbs/in Rear: 564 lbs/in, 14/10 KG/MM
JIC FLTA2 Series, NA FWD Front: 787 lbs/in Rear: 506 lbs/in, 14/9 KG/MM
TEIN HA Series, Turbo AWD Front: 671 lbs/in Rear: 448 lbs/in, 12/8 KG/MM
TEIN S.Tech Springs Turbo AWD Front: 230 lbs/in Rear: 160 lbs,4.2/2.8 KG/MM/in
TEIN Luxury master Springs Turbo AWD Front: 670 lbs/in Rear: 280 lbs/in,3.9/2.6 KG/MM
TEIN Flex Coilovers Turbo AWD Front: 230 lbs/in Rear: 160 lbs/in, 12/5 KG/MM
Eibach (2811.140) Pro-kit Series variable rate, Front: 228 to 428lbs, Rear: 154 to 228 lbs.
Intrax ?
H techs Front: 218 lbs/in Rear: 145 lbs/in 3.9 kg/mm / 2.6 kg/mm /
Stock Spring Rates:
All units in N/mm (lbs/in.)
Stock Spring Constants
'92-'93 FWD AWD
Front 30 (168) 39 (218)
Rear 35 (196) 28 (157)
'94+
Front 29 (162) 38 (212)
Rear 34 (190) 28 (157)
Spyder
Shock Damping Forces (0.3m/s or 0.984ft/sec)
ECS (all) Expansion Contraction
Front Hard 2530(558) 1190(262)
Front Med 1580(348) 1120(247)
Front Soft 620(214) 970(214)
Rear Hard 1710(377) 1010(223)
Rear Med 1160(256) 880(194)
Rear Soft 560(123) 670(146)
Non-ECS Expansion Contraction
Front 1080(238) 540(119)
Rear 1000(220) 550(121)
